Thermal Processes: Ideal Gas Expansion with Constant Pressure [SOLVED]
  • Thread starter Thread starter HELLO11
    Thermal
The discussion revolves around solving a thermal processes problem involving the expansion of a monatomic ideal gas at constant pressure. The work done by the gas during expansion is confirmed to be 3.0 x 10^5 Joules. Participants suggest using the ideal gas law (PV = nRT) to find the initial and final temperatures, with a calculated initial temperature of 859.5 K. The change in internal energy is related to the specific heat at constant volume (Cv) and the change in temperature, while the heat added can be determined using the first law of thermodynamics. The conversation emphasizes careful unit management throughout the calculations.
HELLO11
[SOLVED] Thermal Processes
With the pressure held constant at 240 kPa , 42 mol of a monatomic ideal gas expands from an initial volume of 0.75 meters cubed to a final volume of 2.0 meters cubed.
a)How much work is done by the gas during expansion?
b)What were the initial and final temperatures?
c)what was the change in the internal energy of the gas?
d)How much heat was added?
I know the anwser for a) is 3.0*10^5
i can't find the other three
can someone please help
Where have you looked?
Use ideal gas law: PV = nRT. You know P, V and n so just work out T for intial and final states.
What is Cv for a monatomic gas? How is \Delta U related to Cv and \Delta T?
Use first law: dQ = dU + dW
As a short-cut, since it is a constant pressure process, you can just use: dQ = CpdT. What is Cp for a monatomic gas?
Units?
AM
the units for the first answer are Joules
How do i wotk out the T for inital and final states
the Cv for a monatomic gas is 12.465
delta U is 3/2*n*R*deltaT
Cp for a monatomic gas is 20.775
Use the ideal gas law PV=nRT like Andrew suggested in post #3. You were given all the information you need to solve this for T.
For T i get 859.5 How do i get the inital temperature
You just use the ideal gas law twice. Once for the initial state (so before it expands), and once for the final state (after it expands).
Be very careful with your units.
thanks for all your help
