Solving Thermite Reaction: 1 Mole Al + 10.0g Fe2O3
  • Thread starter Thread starter chemister
    Reaction Thermite
The discussion focuses on calculating the amount of unreacted aluminum after a thermite reaction involving iron(III) oxide (Fe2O3) and aluminum (Al). Given that 10.0 grams of Fe2O3 corresponds to approximately 0.0626 moles, it is established that this amount of Fe2O3 will react with twice the moles of aluminum, resulting in 0.1252 moles of Al consumed. Starting with 1 mole of Al, the remaining amount after the reaction is calculated to be about 0.8748 moles, which translates to approximately 23.6 grams of unreacted aluminum.
chemister
Please Help!
I am still having problems with this problem...
It deals with the thermite reaction Fe_{2}O_{3}+2Al----2Fe+Al_{2}O_{3}
If 1 mole of Al is reacted with 10.0g of Fe_{2}O_{3}, how many grams of unreacted Al would remain?
Chemistry news on Phys.org
How many moles of Fe_2O_3 are there in 10g?
There are about 0.0626 moles of Fe_{2}O_{3} in 10.0g
This is a double post.
Anyway no:moles of Fe_2O_3 reacted will be twice no:moles of aluminium.
if only 0.0626 moles of Fe_2O_3 is present then correspondingly 0.0626*2 moles of Al will react.
Al remaining
Assuming 10 g of Fe2O3 = 0.0626 moles (too lazy to look at periodic table),
then Al remains is (1 - (2*0.0626))= 0.8748 mol of Al = approx. 23.6 g of Al
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
