Thermo Question P-V diagram
In summary, this engine combines a diesel cycle and a steam cycle into 1 p-v diagram. The main purpose of the steam power stroke is to maintain a high quality steam at effective pressures, while the traditional exhaust stroke is turned into a compression stroke to help with quality.
KCatBatt
If you were to combine a diesel cycle and a steam cycle (crower cycle) in 1 p-v diagram, what would it look like?
Welcome to PF.
Sorry, but the question doesn't make a whole lot of sense. What, physically, are you describing?
Thanks for the welcome.
I'm talking about a 6-stroke engine, more specifically a Crower cycle.
There will be a intake stroke, compression, combustion, exhaust... and at TDC of the exhaust stroke, water will be injected to harness the otherwise wasted heat and convert to steam... expanding and creating work, then exhausted again and the cycle starts over.
I would imagine it would simply be 2 superimposed cycles (otto/diesel, and rankine) analyzed separately, rather than one cycle since a cycle depicts what is done to a single working fluid. The duty cycles of each are reduced to producing power 1/6 of the time, which might or might not be enough to justify it.
In addition, I'm not sure you could create superheated steam in sufficient quantities in such a short period of time with those temperatures. Rankine cycle steam temperatures are roughly around 800* F, which will never occur in a typical IC engine.
Thanks for the reply.
There will be 2 power strokes every 6 strokes.
The temps are there to phase change to steam at 1atm, but we can still play with the pressures by adjusting the timing at which it's injected, bringing down the pressure below 1atm.
Now the temps are not 800F, but I don't know what pressures you thinking of when you come up with that number. Are you saying that the steam will not be able to do work unless the temps are at 800F?
thanks,
Casey
The quality of steam goes down when pressure goes up (it wants to condense), so you need a higer temperature to maintain a superheated steam (>100% quality) at effective pressures.
And yes, you have 2 power strokes every 6 strokes for a duty cycle of 33%, whereas a 4 stroke has a duty cycle of 25%, so you are right there. However, It seems that the steam power stroke will not produce enough added benefit, not to mention the possibility of residual moisture during combustion since your condensing step is done in the cylinder (if i understand correctly).
It would look like two superpose traditional cycles (one smaller that the other).
1- Traditional compression stroke
Traditional heating by combustion of fuel
2- Traditional power stroke
3- Traditional exhaust stroke (flat line @ Patm)
Heating of water injected by residual exhaust heat (creating pressure rise when liquid change to steam)
4- Steam power stroke
5- Steam exhaust stroke (flat line @ Patm)
6- Traditional intake stroke (flat line @ Patm)
Of course, when I say "flat line @ Patm", that's in theory. In reality, there are always some pumping losses that will make these strokes deviate slightly from Patm.
There might also be some gain in transforming the traditional exhaust stroke (#3) into a slight compression stroke (early valve closing) to help the quality of steam.
1. What is a P-V diagram?
A P-V diagram, or pressure-volume diagram, is a graphical representation of the relationship between the pressure and volume of a gas or fluid at a constant temperature. It is commonly used to analyze thermodynamic processes and can provide information about work, heat, and efficiency.
2. How is a P-V diagram constructed?
A P-V diagram is constructed by plotting the pressure on the vertical axis and the volume on the horizontal axis. The process is typically done on a Cartesian coordinate system and can be created by measuring the pressure and volume at different points during a thermodynamic process.
3. What information can be obtained from a P-V diagram?
A P-V diagram can provide information about the work done by a system, the heat added or removed, and the efficiency of a process. It can also show the direction of the process (expansion or compression) and the final state of the system.
4. What are some common shapes of P-V diagrams?
Some common shapes of P-V diagrams include rectangular, triangular, and trapezoidal. These shapes can represent different types of thermodynamic processes such as isobaric, isochoric, and adiabatic.
5. How are P-V diagrams used in real-world applications?
P-V diagrams are used in a variety of real-world applications, such as in the design and analysis of engines, refrigeration systems, and power plants. They are also used in the study of thermodynamics and in the development of new technologies for energy conversion and storage.
  • Mechanical Engineering
