Thermodynamic state having 2 degrees of freedom (i.e., for properties)
The discussion centers on the concept of thermodynamic states with two degrees of freedom (DOF) and the relationship between fundamental properties such as pressure, volume, temperature, entropy, and internal energy. It highlights that with five properties, having two DOF implies three constraint equations, with the First Law of Thermodynamics and the Ideal Gas Law providing two of them. The conversation introduces Gibbs' Phase Rule to explore additional constraints, noting that the topology of the system is two-dimensional, allowing for a maximum of three phases at a single point. The discussion also emphasizes that true-extensive properties, specifically temperature and pressure, dictate the DOF outside of saturation states, while questioning the exclusion of intensive properties from this framework. Overall, the conversation seeks to uncover deeper reasons behind these thermodynamic relationships.
swampwiz
TL;DR Summary
What is the underlying reason that thermodynamic state has 2 degrees of freedom - i.e., that any 2 properties (saturated state excepted) completely determines the state?
I'm trying to delve into the reason why this is so. It seems that there are 5 fundamental properties:
P - Pressure
V - Volume (specific)
T - Temperature
S - Entropy (specific)
U - Internal Energy
(Yes, there are other types of energy, but they are fully determinable from these 5 - e.g., Enthalpy: H = U + PV)
Since there are 5 such possible domain variables, having a net of 2 DOF means that there must be 3 constraint equations. The 1st Law of Thermodynamics provides 1 of the equations:
dU = δQ - δW = T dS - P dV
so what are the other 2?
I can see for an ideal gas that the Ideal Gas law provides another:
p V = R T
but even for this model, there must be yet another.
Do you know about "Gibbs' Phase Rule"? That might help to answer your question
Likes Chestermiller
So it seems that because the the 1st Law of Thermodynamics involves only 2 true-extensive properties T & P (i.e., specific Volume or Entropy is not a true-extensive property), the topology is as per a 2-D domain, with the result that phases are regions within that domain, and thus a maximum of 3 phases can exist at single points, with there being 0 DOF of those true-extensive properties there (e.g., the triple point has no DOF - it is a singular point), and such that along points at which there are 2 phases (i.e., saturation paths), there is 1 DOF of true-extensive properties (e.g., saturated water liquid/vapor has a specific temperature for a given pressure and vice-versa), and thus 2 DOF when inside a solitary phase.
However, this idea can be simplified such that the number of true-extensive properties is the number of DOF outside of a saturation state. But this doesn't explain why intensive properties are not part of the DOF. I think there is a deeper reason here.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
