Thermodynamics and microwaving food
Microwaving food in a plastic container can lead to warping and buckling due to changes in temperature and pressure. When the container cools, water vapor may escape, creating a partial vacuum that causes the walls to buckle inward. This indicates that the volume is not constant, and the number of particles may not be conserved. Additionally, heating plastic can lead to chemical outgassing, potentially contaminating the food. It is advisable to use a different type of dish for microwaving to avoid these issues.
berra
Hi, I just microwaved some food in a plastic container and noticed that it started to buckle inwards. So I wonder what thermodynamic variables were constant? Obviously not the volume V. The number of particles N was probably approximately constant. What more than N was constant?? What ensemble should I use if I want to do computations on this??
Science news on Phys.org
What computations? Use a different type of dish to microwave your food.
Thermodynamical computations. Gibbs free energy requires temperature and pressure constant, for example. But the temperature is certainly not constant when heating in a microwave.
If it buckled inwards (and warpage of the plastic was not a problem, see SteamKing response), some mass of water vapor must have escaped from the container during the heating. If it only buckled when the container cooled down, then this is almost certainly what happened. When the container cooled, the remaining water vapor in the container mostly condensed, and this created a partial vacuum in the container. The walls were not structurally stiff enough to support the pressure difference.
Chet
Alternatively the plastic container warped with the heat and became permanently warped. If that's the case then
1st: The volume changed because the container changed, particles were most likely lost. N is not conserved.
2nd: The plastic outgassed some chemicals into your food contaminating it. I wouldn't use this kind of container in the micro-wave any more.
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
