Thermodynamics In An Isolated System
In an isolated system with a star radiating energy, the environment's temperature cannot exceed that of the star until thermal equilibrium is reached. The conservation of energy remains intact as the star converts mass into energy, and this scenario does not violate the zeroth law of thermodynamics. As the star radiates, the environment absorbs energy, gradually increasing its temperature. Once the temperatures equalize, radiation from the star will balance with that from the environment. Ultimately, the environment will glow when it reaches the same temperature as the star, adhering to the principles of thermodynamics.
BOAS
Hello,
I was thinking about a situation last night and couldn't convince myself of a correct answer, so I thought i'd put it to you guys.
Imagine an isolated system containing a star at some temperature radiating a given amount of energy into the environment. Can the environments temperature ever exceed that of the star?
I don't think such a situation would violate conservation of energy, because the star is converting mass into energy. But does this violate zeroth law?
My thoughts were that as the star radiates energy into the environment, it cannot escape and continues to build up due to the thermal radiation of the star. Given enough time, the system will reach thermal equilibrium, but can the environment exceed the temperature of the star at any point?
Thanks!
Science news on Phys.org
If we assume:
- The star and the environment are two separate systems, where heat is allowed to flow across their boundary.
- The initial temperature of the environment is less than that of the star.
- The star has a heat source, the environment has no heat source.
Then the environment will never have a temperature greater than the star until the two systems reach equilibrium. There also is nothing in this set-up that may suggest it could violate the zeroth law.
As the environment gets hot, the environment will start to glow according to the Stephan-Boltzmann law. When it reaches the same temperature as the star, the radiation from the star to the environment will equal the radiation from the environment to the star. Note that thermodynamics requires that the emissivity coefficient in the SB law equals the absorptivity coefficient.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
