Thermodynamics: internal energy
The internal energy equation U=q+W includes total work, not just pressure work. Substituting -PV into W represents pressure-volume work, but other forms of work, such as electrical work in batteries and fuel cells, should also be considered. The total work can be expressed as W = -P dV + W_other. Understanding these distinctions is crucial for accurate thermodynamic calculations. Comprehensive analysis of work types enhances the application of internal energy in various systems.
iScience
internal energy U=q+W
so far we've only been substituting -PV into W but i just wanted to be sure that the W is the total work and not just the work done by the pressure right?
Science news on Phys.org
Right. Another common kind of work is electrical, when looking at the thermodynamics of batteries and fuel cells, for instance. You will often see fomulations of the kind
W = -P dV + W_\text{other}
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
