Thermodynamics is air ducts, dew point
The airflow inside an air conditioning duct, particularly when cooled, behaves more like constant pressure rather than constant volume. This is important for accurately determining the dew point of the air flow. While there is a small pressure differential created by the fan, it is negligible in the context of the overall airflow. Therefore, for practical purposes, assuming constant pressure is a valid approximation. Understanding this distinction is crucial for HVAC system analysis and performance evaluation.
rolan91602
Can anyone confirm if the flow of air inside an air conditioning duct, when cooled, behaves as constant volume as compared to constant pressure? I am trying to determine the dew point of the flow and, depending of how it behaves inside the duct, this value will depend on if it is at constant voulume or constant pressure. I think it is at constant volume. Please confirm.
Science news on Phys.org
The duct is open on both ends. There is going to be a small pressure differential due to the fan, required to move the air, but it's going to be almost insignificant. To a good approximation, you can assume constant pressure.
Thank you.
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
