Thermodynamics Question- Melting Temp
The discussion revolves around calculating the melting temperature of a protein at high pressure using given thermodynamic parameters. The entropy change for denaturation is provided as 2.31 J/Kmol at 1 atm and 338 K. Participants suggest utilizing the Clausius-Clapeyron relation to approach the problem. The heat capacity change (∆Cp,m) and molar volume change (∆Vm) are also noted as important factors in the calculation. The thread highlights the need for guidance on initiating the solution process.
jessedevin
For a protein denaturation the entropy change is 2.31J/Kmol at P = 1.00 atm and at the melting temperature T=338K. Calculate the melting temperature at a pressure of P= 1.00x10^3 atm if the heat capacity ∆Cp,m= 7.98J/Kmol and if ∆Vm=3.10mL/mol.
∆S=∆H/T
I am completey stuck. If someone could give me a tip on how to start, maybe I can get the ball rolling and solve this problem.
"Clausius-Clapeyron relation"
