Calculating Power Output and Heat Dissipation in a Coal-Powered Plant
In summary, the power plant consumes 20,000 tons of coal per day with an average heat value of 26,000 Btu/kg and an overall efficiency of 28%. To find the average electrical power output in kilowatts, the given information needs to be converted to the desired units. This is achieved by first converting the tons to pounds and then to kilograms, and then multiplying it by the heat value and dividing by the time frame of 86,400 seconds. The result is 3,367,003.367 kJ/s. The second part of the equation, which asks for the heat dissipated per day in Btus, can also be calculated using the same method.
chrisama
A power plant consumes 20,000 tons of coal per day; the average heat value of the coal used is 26,000 Btu/kg and the overall efficiency is 28%.
What s the average electrical power output of the plant in kilowatts?
How much heat is dissipated per day, in Btus?
I think that this equation may be helpful, but I'm not sure---P=E/t
I realized that I must get the units into pounds, so I converted the tons into pounds and got 400,000. I also thought of dividing by 24 since 24 hours is the time frame, and power is granted by energy over time. However, I think that my attempt at this problem is totally wrong. I'd greatly appreciate your help.
Your relevant equation is very important. Power is energy per time. You are trying to find the power output (energy per time). The given info is 20,000 tons/day valued at 26,000 btu/kg. Looking at the given info i see both energy and time. It wants your answer in kilowatts (kJ/s). Try putting the given info together somehow converting where necessary to achieve the desired units. Also remember to apply the efficiency.
Your attempt is on the right track, but you got to take it further. Remember to write out the units along the way and hopefully you will see how to get from the given info to the output.
Okay, I will now work it out on my own and display what I get soon.
So, I worked out the equation and got 3,367,003.367 Kj/s for the first part.
This is how I did it:
I first got the time, which is 86,400 seconds.
Then I multiplied the 26,000btu/kg by 1.055kj/btu, which gave me 27,430 kj/kg.
Next, I converted the 20,000 tons into 40,000,000lbs. Then, I converted that into kg by dividing by 2.2. Once, I did that, I received 18,181,818 kg.
Then, I multiplied the 18,181,818kg by the 26,000 kJ/kg in order to get a unit of 2.9091E^11 KJ. I divided this number by 86,400 and received 3,367,003.367 kj/s.
I hope this is correct. I'm not trying to figure out the second part of the equation.
I got it. thanx.
1. What is thermodynamics?
Thermodynamics is the branch of physics that deals with the conversion of energy from one form to another and the relationships between heat and other forms of energy.
2. What are the laws of thermodynamics?
The laws of thermodynamics are fundamental principles that govern the behavior of energy and its transformation in physical systems. They include the first law, which states that energy cannot be created or destroyed, and the second law, which states that the total entropy of a closed system always increases over time.
3. What is the difference between heat and temperature?
Heat is a form of energy that is transferred between two objects due to a temperature difference. Temperature is a measure of the average kinetic energy of particles in a substance.
4. How is thermodynamics applied in real life?
Thermodynamics has countless applications in various fields, including engineering, chemistry, and biology. It is used to design efficient engines and power plants, understand the behavior of materials, and analyze chemical reactions.
5. What is the role of entropy in thermodynamics?
Entropy is a measure of the disorder or randomness in a system. In thermodynamics, it is closely related to the second law and is used to determine the direction of energy flow and the efficiency of processes.
  • Electrical Engineering
