fluidistic
- 272
Hello guys, I'm stuck on a problem I've met in an exam and that I will roughly copy out of memory.
There was a substance that had a transition to liquid helium at ##T_0=3##K. Also, ##M=\frac{nDB}{T}## (Curie's law was satisfied). Specific heat at constant magnetization was given: ##C_M= nAT^3##.
The goal was to cool the substance below 3K if I remember well. In order to do so, they would magnetize the substance isothermally (at ##T_0##) up to ##M_0##. Then they would demagnetize the substance adiabatically in order for it to cool down.
Assuming that the heat produced by the substance during the isothermal process is Q,
1)Find ##M_0 (n,D,Q,T_0)##.
2)Find T(M) in the adiabatic process.
3)Calculate the final temperature of the substance.
(1):##C_M = \left ( \frac{\partial U}{\partial T} \right ) _{M,n}##
(2):##\left ( \frac{\partial U}{\partial M} \right ) _{T,n}=B-T\left ( \frac{\partial B}{\partial T} \right ) _{M,n}##
I know that ##B=\frac{TM}{nD}##. So using equation (2), I get that ##\left ( \frac{\partial U}{\partial M} \right ) _{T,n} =0##. This means that U is a function of T and n, it doesn't depend on M.
From eq. (1) and ##C_M= nAT^3##, I get that ##U(T,n)=\frac{nAT^4}{4}+f(n)##. In the problem I'm sure we can assume that the substance has a fixed n. So n is a constant.
I apply the 1st law of thermodynamics for the isothermal process, ##\Delta U=-Q+W## where W is the work done BY the system during that process.
But ##\Delta U=0## for the isothermal process, because U only depends on T (and n, but n is fixed).
Therefore the work done ON the system is equal to the heat released BY the system.
Work done by the system is ##-\int BdM=-\frac{B_0 ^2 T_0}{2nD}##
So ##Q=\frac{B_0^2T_0}{2nD}##. And ##M_0=\frac{nDB_0}{T_0}##. So I reached that ##M_0 (T_0, n D, Q )=\left ( \frac{nD}{T_0} \right ) ^{3/2} (2Q)^{1/2}##. That result looks so weird to me, I can't believe it is right.
I haven't figured out the other 2 questions yet.
I'd appreciate some feedback on the first question. Thank you.
