Engineering Thevenin equivalent circuit with dependent current source
To find the Thevenin equivalent circuit with a dependent current source, the Thevenin resistance is determined to be 1 kΩ. The Thevenin voltage is identified as the voltage across the 300 Ω resistor. Using a voltage divider to calculate this voltage is suggested, but caution is advised due to the presence of the controlled source. It is recommended to apply a test source at the output terminals to accurately determine the Thevenin resistance. This method accounts for the effects of the controlled source on both voltage and resistance.
Kuuie
Find the thevenin equivalent circuit of the circuit to the left of the terminals AB.
Circuit diagram is attacted below.
I know that the thevenin resistance is 1kohm.
I also know that the thevenin voltage is the voltage across the 300 ohm resistor.
Im thinking of using a voltage divider to calculate the voltage v2, but surely it cannot be that simple. I am really not sure how to approach this.
Thanks in advance
Thanks in advance
Hi Kuuie, Welcome to Physics Forums.
The controlled source is going to mess with both the Thevenin voltage and resistance. Usually you can't just suppress a controlled source along with any fixed sources to find the equivalent resistance of the remaining network.
An approach for cases where there are controlled sources is to put your own source on the output terminals and find the corresponding voltage or current that results. The Thevenin resistance will be the Voltage/Current that this new source provides.
  • · Replies 42 ·
  • · Replies 17 ·
