Engineering How Do You Calculate Thevenin Equivalent Circuits and Current Flow?
The discussion revolves around calculating the Thevenin equivalent circuit for an unknown circuit with a variable resistor (RL) that dissipates a maximum power of 10W at 25 ohms. The derived Thevenin equivalent circuit is a 22.4V power supply with a 25-ohm resistor. When RL is set to 5 ohms, the calculated current flow is 0.74A. There is confusion regarding the correct application of power formulas, with participants debating between using P=V^2/R and P=I^2*R. Ultimately, the calculations are deemed numerically correct, but there are concerns about the interpretation of voltage across the resistors in the circuit.
Solidsam
A variable resistor (RL) is connected to an unknown circuit. It is found that the
maximum power that can be dissipated in the resistor (RL) is 10W, and that this
occurs when the value of the resistor (RL) is 25ohms.
Derive the Thevenin equivalent circuit for the unknown circuit, and hence find the
current which flows when RL = 5ohms.
Maximum power dissaption occurs when RL=RS which was 25ohm
Which means P=V^2/R= V=sqrootof P*R = sqrootof 10W*(25+25)ohms=22.4V
Equivalent circuit is a 22.4 V power supply and a 25 ohm resistor
When RL is 5 I=V/(Rs+RL)=22.4/(25+5)=0.74Amps
are my calculations correct?
P does equal V2/R, but the 10W of power is being dissipated by RL, not RL + RS.
so do i use P=(V^2/R) or P=I^2*R
if i use P=(V^2/R) i get V = sqrootof(25*10)=15.81V
if i use P=I^2*R i get I=sqrootof(10/25)=0.632A V=R*I=15.81V
Then I=V/(RL+RS)= 15.81/(25+5)=0.527A
Your calculations are numerically correct but your result is wrong. You have gotten off the track with this line:
First off, what did you get for the Thevenin equivalent of the unknown circuit?
a 15.81 voltage power supply connected to a 25ohm resistor?
If you had a current going through RL=25ohms producing a voltage of 15.81V, what voltage would be produced across RS?
  • · Replies 35 ·
  • · Replies 42 ·
