Three Phase Troubleshooting: Calculating Voltage & Current
  • Thread starter Thread starter robcowlam
    Phase Three phase
In a balanced delta-connected load of 30+18.86j ohms with a voltage of 400V, the phase voltage is equal to the line voltage. The impedance calculation yields a magnitude of 35.43 ohms at an angle of 32.14 degrees. The current is calculated as I = V/Z, resulting in 11.29 at -32.14 degrees. However, the angle appears to be 30 degrees out, possibly due to a misunderstanding of the phase relationship between line and phase voltages. Clarifying the distinction between line current and phase current is essential for accurate calculations.
robcowlam
Hi guys,
Im having some trouble with a question about 3 phase power system. I have a balanced delta connected load of 30+18.86j ohms. The voltage is given as 400v @Hz and I am asked to calculate the phase voltage and current using the voltage Vr as the reference.
Now from my knowledge of 3 phase I understand that with this type of load the line and phase voltage are the same (400v) with each phase 120deg lagging from the previous.
Z= 30+18.86j = 35.43 @ 32.14degrees
This leads me to do the calculation:
I = V/Z = (400 @ 0 degrees)/35.43 @ 32.14degrees = 11.29 @ -32.14 degrees.
Repeating this for the other 2 phases gives answers with +/- 120degrees
The magnitude is correct however the angle is 30 degrees out and I cannot see why, the only thing I can think of is that the line voltage is 30degrees out of phase with the phase voltage which I am using as the reference.
Does anyone have any idea if this might be a correct assumption?
Thanks in advance,
Rob
There is a difference in line current and phase current. What is your target variable?
