How Can I Estimate the Cutoff Voltage of a MOSFET From a Graph?
To estimate the cutoff voltage of a MOSFET from a graph, one should plot √(-Id) against Vgs while ensuring the device is in the saturation region, typically at Vds around -7V or -8V. The intercept of this plot will provide the threshold voltage (Vt), which indicates the gate voltage required for the MOSFET to conduct. The threshold voltage is approximately -6 volts, as no current flows unless the gate voltage exceeds this level. A graph of drain current versus gate voltage would yield more useful information for analysis. Accurate extraction of the threshold voltage can be achieved through the suggested plotting method without additional measurements.
Lith1um
Hi,
I recently conducted a lab experiment involving several mosfets of varying channel length and width and have plotted Ids against Vds for different values of Vgs (below is one of the graphs).
I am now trying to find the threshold voltage of each mosfet using their graphs although I am having trouble figuring out how to do that and cannot find much help that is already online (I'm probably just bad at using google). Any help concerning this would be greatly appreciated.
Thanks,
Alex
If you look up the equations for the current of a MOSFET, you will find that in the saturation region:
I_d \propto (V_{GS} - V_T)^2
So, I would choose a value of Vds where the device is in the saturation region (Vds = -7V or -8V looks good), and the plot √(-Id) vs Vgs. The intercept should give you Vt.
The threshold voltage is the voltage needed from gate to source to make the FET conduct current from drain to source.
You can estimate this from your graph. It is about -6 volts, because no current flows at any collector voltage unless the gate voltage is at least -6 volts.
The threshold voltage is significantly less (in magnitude) than 6V, which you will see if you make the graph I recommended.
The question asked was, using THAT graph, how would you estimate the cutoff voltage.
Given that the lowest value of gate voltage given is -7 volts, you could just say " something less than 7 volts".
There may be some non linearity in the turn-on behaviour of the FET but we don't know at this stage.
The graph of drain current vs gate voltage would be much more useful, as you suggest.
You're not getting it. You can quantitatively extract the threshold voltage from the graph that the OP has by just generating the plot I suggested. No more measurements are required. This will give you a much more accurate value than "less than 7V".
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
