Time an electron spent in a magnetic field
To determine the time an electron spends in a magnetic field with a strength of 0.5T and an angle of deflection of 30 degrees, one can calculate the time period T for a full 360-degree rotation. Given the magnetic field, the time for the electron to travel 30 degrees can be derived from the total time period. The discussion concludes with a participant expressing gratitude for the clarification and confirming their understanding of the concept. This approach effectively simplifies the calculation of time in the magnetic field.
luisabejarin
Hello.. Does anyone know how to find the time t an electron spent in a magnetic field region if the only thing given are the magnetic field B=0.5T and angle of deflection 30 degrees?
You can find time period T of electron as you know B. Electron travels 360 deg in T, so what time will it take to travel 30 deg, you can find.
wow!thanks,i got it..i understand..thank u very much!
