Time-dependent Perturbation Theory
The discussion revolves around Time-Dependent Perturbation Theory as presented in Griffiths' "Introduction to Quantum Mechanics." Participants are examining the definitions and implications of the coefficients \(c_a(t)\) and their behavior under perturbation, particularly focusing on the first-order correction.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are questioning the definition and role of the coefficients \(c_a(0)\) and \(c_a(1)(t)\), particularly why the first-order correction is also equal to 1. There are discussions about the nature of successive approximations versus asymptotic expansions.
There is an active exploration of the definitions and interpretations of the terms used in the equations. Some participants are providing insights into the implications of initial conditions and the nature of perturbations, while others express uncertainty about the terminology and methods used in the text.
Participants note that the initial conditions are assumed to hold for all orders of approximation, and there is a lack of clarity regarding the presence of a small parameter in the author's approach.
Viona
Why the first-order correction equals 1 instead of arbitrary constant?
I was reading in the Book: Introduction to Quantum Mechanics by David J. Griffiths. In chapter Time-Dependent Perturbation Theory, Section 9.12. I could not understand that why he put the first order correction ca(1)(t)=1 while it equals a constant.
How are the ##c##'s defined? I ask because (1) I'm too lazy to go get my copy of Griffiths and (2) it may provide the answer to your question.
He used a process of successive approximations, so for this two particle system the particle starts at state ##a##, then at time t=0: ca(0)=1 and cb(0)=0. If there were no perturbation the system will stay there forever, so we can say the zeroth- order terms are: ca(t)=1 and cb(t)=0. To calculate the first order terms we plug the zeroth order terms in the equations [9.13] below:
Recall equation [9.15], which says ##c_a(0) = 1##.
In equation [9.15] ##c_a(0) = 1## this is before the perturbation (at time ##t= 0##) no transition happened yet and the particle still in the upper state ##a##. But equation [9.17] after perturbation at time t and ca(1)(t) = 1 is the first-order correction. I understand that the zeroth-order ##c_a(t) = 1## but why the first-order correction also =1?
Viona said:
In equation [9.15] ##c_a(0) = 1## this is before the perturbation (at time ##t= 0##) no transition happened yet and the particle still in the upper state ##a##. But equation [9.17] after perturbation at time t and ##c_a(1)(0) = 1## is the first-order correction. I understand that the zeroth-order ##c_a(t) = 1## but why the first-order correction also =1?
How many constant functions do you know that fulfill ##c_a(0)=1##?
Initially I agreed with you, but the passage in your original post defines c^{(1)} not as the "first order correction" but the "first order approximation".
To my mind, if we speak of perturbing a system y' = f(x,y) subjec to y(0) = 1 then the perturbed system is y' = f(x,y) + \epsilon g(x,y) for some small parameter \epsilon. We would then pose an expansion of the form y(x) = y_0(x) + \epsilon y_1(x) + \dots, and we would then call y_1 the first order correction. And if we don't perturb the initial condition as well then indeed y_0(0) = 1 and y_1(0) = 0.
But here the text (at least the parts you've posted) doesn't mention a small parameter, and you have described the author's method as "successive approximation" rather than "asymptotic expansion". This would be like obtaining approximate solutions to our perturbed system by the iterative process <br /> y_{n+1}(x) = 1 + \int_0^x f(x,y_n(x)) + \epsilon g(x,y_n(x))\,dx for which y_n(0) = 1 always holds.
The initial conditions at ##t = 0## are assumed to hold for all orders of approximation. So, when you solve the first-order equation ##\dot c_a(t) = 0##, you can use the initial condition ##c_a(0) = 1## to show that ##c_a(t) = 1## for all ##t \ge 0## for the first-order approximation.
To my mind, if we speak of perturbing a system y&#039; = f(x,y) subjec to y(0) = 1 then the perturbed system is y&#039; = f(x,y) + \epsilon g(x,y) for some small parameter \epsilon. We would then pose an expansion of the form y(x) = y_0(x) + \epsilon y_1(x) + \dots, and we would then call y_1 the first order correction. And if we don't perturb the initial condition as well then indeed y_0(0) = 1 and y_1(0) = 0.
He said he is going to use a process of successive approximations, I am not familiar with the "asymptotic expansion" so I can not tell if this what he did
