I Time Dilation, Clocks, & Gravity
Pushoam
In the rest frame , the measured time interval is the time elapsed between the two ticks (so two events T1and T2) of one clock.
In moving frame,the time elapsed between the two ticks T1and T2 are measured by the two synchronized clocks kept at two different places x'1 and x'2.
The information that the rest clock has ticked first time reaches to the clock at x'1 at some time say t'1 and the information that the rest clock has ticked the second time reaches to the clock at x'2 at some time say t'2.
The information reaches in such a way that t'2 - t'1> t2 -t1.
If the information can travel with infinite speed , there will be no time - dilation.
But in this case , for different kinds of clocks e.g. sound and light clock, time dilation should be different.
So, this reasoning is wrong.
Should I simply take it for granted that time - dilation is property of space - time?
The only reason to imagine time dilation was all the experiments that measured the speed of light as the same no matter what inertial reference frame the measurement instruments were in. That is why the time dilation is tied to the speed of light. The same can not be said about the speed of sound. The argument for time dilation must reference the constant speed of light or it is flawed. Just talking vaguely about "information" is not enough.
Likes Pushoam
The phrase "speed of light" refers to the speed, not the light. This speed is the fastest speed possible because it's the speed that's the same in all inertial reference frames. Thus information cannot travel faster than this speed, and that is the crux of this argument. It has nothing to do with the fact that light happens to have this speed. If we were to discover that light travels slower than this speed it woud change nothing in the theory. We'd just refer to ##c## as the invariant speed rather than the speed of light, as many people already do so as to avoid these types of misunderstandings.
Good point. Light was the focus of the experiments, but it was not specifically essential to the theory. But neither was "information". The OP puts too much reliance on information speed regardless of means of transmission. Comparing information transmitted electromagnetically with information transmitted by sound is very wrong for understanding SR.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
