Time to drain water through a pipe
The problem involves a closed vertical cylindrical tank draining water through a hole at the bottom, with specific dimensions and a constant gauge pressure applied to the water surface. The subject area relates to fluid dynamics, particularly the application of Bernoulli's equation and the continuity equation in determining the time it takes for the tank to empty.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss calculating the flow of water through the hole and the relationship between the velocity of the water and the height of the water column. There are attempts to derive a differential equation relating the volume of water in the tank to the height over time. Some participants question the treatment of variables and the assumptions made in their calculations.
There is an ongoing exploration of the relationships between pressure, velocity, and volume. Some participants have provided insights into using Bernoulli's equation to derive expressions for velocity and have noted the importance of treating certain variables as functions of time. Multiple interpretations and approaches are being discussed, with no explicit consensus reached yet.
Participants are working under the assumption that viscosity can be ignored and are focusing on the effects of pressure and gravitational potential energy in their calculations. There is also a mention of the need to clarify the distinction between the areas of the tank and the hole.
Bruneleski
A closed and elevated vertical cylindrical tank with diameter 2m contains water to a depth of 0.8m.
A circular hole is made at the bottom of the tank with diameter 0.2m.As the water drains from the tank, compressed air above the water in the tank maintains a gauge pressure of 5000Pa at the surface of the water.
Ignore viscosity.How much time does it take for all the water to drain from the tank?
Continuity equation
I have no idea how to approach a problem like this in general but here is what i thought:
I can calculate water flow through a small hole using
[tex] dV/dt=A\upsilon[/tex]
Now
[tex] dt=dV/A\upsilon[/tex]
and integrate both sides to get t.
Unfortunately, I get nowhere.Units do not match and so on.I don't know if this is even conceptually right.
Now a friend of mine says i should watch out for dh/dt rate, but I can't see how is that useful
That approach is fine, but you have to find v as function of volume or (better) height.
Think of energy conservation. To flow out with speed v, the water needs energy, and its volume goes from a region with high pressure to one with lower pressure.
I can get that using Bernoulli.
p1+ρgy1+½ρ v12=p2+ρgy2+½ρ v22
½ρ v12 is zero because v1<<v1
ρgy2 is zero because potential energy at the bottom of the tank is 0
pressure p1 at the water surface is constant 5000Pa (it says so in text).
pressure at the bottom(hole) is assumed zero(it says so in text).
so we pull out water velocity at bottom(hole)
v=v2= sqrt(2p1/ρ+2gy1)
we plug that and take integral
t=∫(dV/Av) from initial volume V to V0=0 when water is completely drained
but because Av is constant we can take it outside the integral and integrate dV and get
t=-½V2/Av with units completely off (which obviously originates from the V^2)
Using your notation, if y1 represents the depth of water in the tank at any time, and AT represents the cross sectional area of the tank, what is the volume of water in the tank at any time? According to the continuity equation, the rate of change of this volume has to be equal to minus the velocity out the bottom hole times the cross sectional area of the bottom hole. You should obtain a differential equation for dy1/dt in terms of y1.
Chet
Integrating dV' would give V, in the same way as integrating dt' gives t on the other side of the equation.
v is not constant.
@chet
Woah, I treated the y1 as the constant all the time instead of variable of time.
Volume of water at any time is dy1(which changes over time) times the area of a cylinder.
I substituted that and got easy differential equation.
Thanks guys.
EDIT: I didn't see your and mfb's further responses. I'll leave my post just in case. I'm surprised you got an 'easy' ODE. Mine required separation of variables.
[tex] Good start, except v is always +. Note that v = v(h=0). h=0 at hole. I'm using v for hole velocity. You also have dV/dt = A<sub>1</sub>dh/dt. <br /> <blockquote data-attributes="member: 523389" data-quote="Bruneleski" data-source="post: 5080326" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> Bruneleski said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> I can get that using Bernoulli.<br /> <br /> p<sub>1</sub>+ρgy<sub>1</sub>+½ρ v<sub>1</sub><sup>2</sup>=p<sub>2</sub>+ρgy<sub>2</sub>+½ρ v<sub>2</sub><sup>2</sup><br /> <br /> ½ρ v<sub>1</sub><sup>2</sup> is zero because v<sub>1</sub><<v<sub>1</sub><br /> ρgy<sub>2</sub> is zero because potential energy at the bottom of the tank is 0<br /> pressure p<sub>1</sub> at the water surface is constant 5000Pa (it says so in text).<br /> pressure at the bottom(hole) is assumed zero(it says so in text).<br /> so we pull out water velocity at bottom(hole)<br /> <br /> v=v<sub>2</sub>= sqrt(2p<sub>1</sub>/ρ+2gy<sub>1</sub>) </div> </div> </blockquote>This is right. Remember y<sub>1</sub> = y<sub>1</sub>(t).<br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> we plug that and take integral<br /> <br /> t=∫(dV/Av) from initial volume V to V<sub>0</sub>=0 when water is completely drained<br /> but because Av is constant we can take it outside the integral </div> </div> </blockquote>v is not constant! v is velocity of hole water which starts max. and ends up zero when the tank is empty.<br /> WARNING: are you confusing A, the area of the tank with A, the area of the hole? I think so.<br /> You have v(y<sub>1</sub>). You also have v as a function of dy<sub>1</sub>/dt.<br /> So form an ODE with y<sub>1</sub> as dependent variable and t as independent. Solve for y<sub>1</sub>(t). Find the constant of integration (the ODE is separable) , set y<sub>1</sub> = 0 and solve for t=T.[/tex]
  • · Replies 16 ·
10K
