Tips on doing well on this time of class test?
The discussion centers on a new testing format in a physics program at Trent University, where traditional written midterms have been replaced with interactive multiple-choice tests. Each question is conceptual and allows only one minute for response, which has led to significant stress and poor performance for some students. The format requires quick thinking and decision-making under pressure, which can be challenging, especially with complex questions that involve manipulating multiple equations. Participants in the discussion suggest strategies for improvement, such as thorough preparation and relaxation techniques to manage anxiety. There is also a debate about the nature of the questions, with some arguing that the complexity may indicate a misunderstanding of the material rather than a true assessment of conceptual knowledge. Overall, the emphasis is on finding effective strategies to adapt to this high-pressure testing environment, which constitutes a substantial portion of the overall grade.
p3t3r1
Hello in my physics program at Trent university (Canada) we have replaced written midterms with interactive tests where we are given a remote and multiple choice questions on the slideshow.
For each question ( all conceptual) 1 minute is given per question (5 choices per question). Each test worth 12% of our grade and we have 4 class tests in total. I have already had one test so far (2nd one coming very soon) which I did very poorly.
We sit in the lecture hall and each of have a remote that corresponds to our student file. Whatever button we press get recorded and the last button we click before the timer is up on each question is recorded as our response to that question.
I can't seem to function well when placed in such a stressful situation. If you give me a written midterm with conceptual questions/ calculations and tell me I have two hours to finish the midterm, that's perfectly all right. I am prepared for that. But for this type of test, where we get 1 minute per question, I either blank out or panic. My brain stops working and I end up watching the countdown timer instead.
Anyone have strategy for doing well in these kind of "new" tests? They worth almost half of our grade so doing well is essential. Thanks.
Wow, one minute per question seems a bit low unless the question is relatively simple. The obvious answer is to study enough so that you know the answer. Also, try to relax and not look at the timer. Take some deep breaths before you start.
CS
The questions are not really straightforward. They are the type of questions you would find in end of chapter conceptual questions in a standard undergraduate physics textbook.
They are usually tricky questions involving you to manipulate equations, usually several at once and sometimes involves you assessing two different situations and compare them etc..
First you say they are conceptual:
Then you say they are not:
Is this significant? Could this mean that you are miscategorizing these problems because you don't really understand them so well? Is it possible that the test is actually telling you something?
Being able to solve a problem eventually may not be a good indicator of understanding - as an example, the fact that someone can solve a one minute conservation of energy problem after spending hours treating it as an equations of motion problem does not mean they understand conservation of energy.
TL;DR Summary: I want to do a PhD in applied math but I hate group theory, is this a big problem? Hello, I am a second-year math and physics double major with a minor in data science. I just finished group theory (today actually), and it was my least favorite class in all of university so far. It doesn't interest me, and I am also very bad at it compared to other math courses I have done. The other courses I have done are calculus I-III, ODEs, Linear Algebra, and Prob/Stats. Is it a...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
