Tolerence measurement +0.02 to + 0.05
  • Thread starter Thread starter raynee
    Measurement
The discussion clarifies the meaning of tolerances +0.02 to +0.05 in fabrication drawings, emphasizing the importance of aiming for the nominal value, typically the midpoint of the tolerance range. For instance, if the nominal is 10.00, the target should be 10.035, allowing for a tolerance of ±0.015. This approach ensures proper fit between parts, such as a shaft and a bore, where the shaft often has a negative tolerance and the bore a positive one. The conversation also highlights that different fits, like press fits or lubricated fits, require specific tolerances to ensure compatibility. Understanding these tolerances is crucial for successful part fabrication and assembly.
raynee
Hi,
I am new here. I would like to know if anyone can explain to me the meaning of +0.02 to +0.05 in a fabrication drawing.Does this part needs to be fabricated in this range of tolerence or,i should follow the maximum value.
Appreciate your replies.
Thanks.
There should be a nominal value associated with the tolerance. That's the value you should try to hit, but the tolerance just gives the acceptable range for inspection not to reject the part.
Likes jack action
You should aim for the middle of the tolerance, or size +0.035. That then gives you a tolerance of ±0.015.
So if the nominal is 10.00, aim for 10.035 and that comes with a tolerance of ±0.015.
Shaft and hole diameters are commonly specified like this. Specifying (e.g) 10.00 as the nominal maintains the design intent, while the shaft will normally a be negative tolerance and the hole a positive one, and that makes it work in the real world.
Likes billy_joule
Tolerances can be used to ensure parts mate correctly.
For example, if you have a machined bore hole which is designed to accept a shaft through it, you could put a tolerance on both items. The Bore hole say 100mm diameter, you could put a tolerance on of your +0.02 +0.05.
For the shaft, you could say 100mm diameter - 0.02 -0.05. What this is doing is to ensure that the shaft will fit in the bore. If you had no tolerance, the bore & the shaft could have an identical diameter, and wouldn't fit.
Yeah, I think I gave some bad advice there. I don't deal much with double plus tolerances like that, so I guess I would make try to build it to the middle of the tolerance zone.
A "press fit" requires the shaft be specified oversize compared with the nominal bore size.
A non-interference or a lubricated fit, requires the bore be specified oversize compared with the nominal shaft size.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
