Topology - How do they know this is open?
  • Thread starter Thread starter quasar987
    Topology
quasar987
The lemma sets out to show that if A in R^n is compact and x_0 is in R^m, then A x {x_0} is compact in R^n x R^m.
They say, "Let \mathcal{U} be an open cover of A x {x_0} and
\mathcal{V}=\{V\subset \mathbb{R}^n:V=\{y:(y,x_0)\in U\}, \ \mbox{for some} \ U\in \mathcal{U}\}
Then \mathcal{V} is an open cover of A."
How do they know that given some U in \mathcal{U}, the associated V is open?
Edit: In fact, consider the following counter example: Let n=m=1, A=[-½,½], x_0=0. Then A x {x_0} is just the segment [-½,½] considered in the R² plane. Let \mathcal{U}=\{B_n(0,0)\}_{n\in\mathbb{N}} (the collection of open balls centered on the origin of radius n). Then, let V_n be the set V associated with B_n(0,0) as described above, i.e. V_n=\{y\in\mathbb{R}:(y,0)\in B_n(0,0)\}=[-½,½], a set that is not open in R. ah!
V_n = (-n, n)
V_n \cap A = [-1/2, 1/2] (for n>0)
Hm, yes. ":frown:" I wish I were smarter than the book.
Meanwhile I think I found the answer. Given an U and it's associated V, for any point y in V, there is an open set O_y in R^n and another one O'_y in R^m such that (y,x_0) is in O_y x O'_y and O_y x O'_y \subset U. And actually, we can write
V=\bigcup_{y\in V}O_y
which is open as an arbitrary union of opens.
Why are you introducing O_y's? If curly(U) is some cover of A x {x}, then projecting into the first coordinate gives an open cover of A, take a finite subcover, and pull back.
I'm introducing the O_y because otherwise, I was not convinced that the projection was open.
After all, as far as I understand, if U is open in a topological space X x Y, it does not mean that it can be written as the product of an open of X with an open of Y.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
