zankaon
- 163
If topology of a manifold were invariant (or not), what specifically would topology of a patch of such manifold in neighborhood (outside) of such BH, suggest?
zankaon said:If topology of a manifold were invariant (or not), what specifically would topology of a patch of such manifold in neighborhood (outside) of such BH, suggest?
zankaon said:If one considered an idealized spherical expansion (of say neutrinos) for a patch of manifold outside a BH
zankaon said:then one could consider such expansion to be finite, bounded (in an orthogonal to the 2-surface) sense,
zankaon said:and hence such expansion per se would be NOT closed. Now if one considered the same gedanken simulation, but for less than BH_h (BH horizon), then the experiment in principle, would seem to have the same topological description, but in an environment becoming more extreme; hence the same manifold (continuum i.e. same inbetweenness).
zankaon said:If one considered an idealized spherical expansion (of say neutrinos) for a patch of manifold outside a BH; then one could consider such expansion to be finite, bounded (in an orthogonal to the 2-surface) sense, and hence such expansion per se would be NOT closed. Now if one considered the same gedanken simulation, but for less than BH_h (BH horizon), then the experiment in principle, would seem to have the same topological description, but in an environment becoming more extreme; hence the same manifold (continuum i.e. same inbetweenness). But yet does one have a construct (BH_h) interspersed between such 2 environments, but with a different topology? Topology commentary is always appreciated.
zankaon said:The ending answer would seem to be no.
zankaon said:For example if a larger BH coalesced with a smaller BH, the former would enlarge. Hence an expansion orthogonal to BH_h. So therefore such expansion (orthogonal to surface) of BH_h would be finite, bounded and thus not closed.
If you haven't read the popular book by Wald, Space, Time, and Gravity, University of Chicago Press, 1977, you would enjoy it!
I have no idea what you seem to be asserting about what happens to the horizon of a black hole when it coalesces with a smaller hole, but it doesn't sound right. To mention just one point, the horizon isn't a physical membrane but an abstract "teleologically defined" surface. At an event on the horizon, nothing in particular happens compared with nearby events, in terms of local physics.
