Torque and vector related. Is this possible.
  • Thread starter Thread starter Laurencio
    Torque Vector
The discussion addresses the confusion in a diagram related to torque and moment arms. It highlights an inconsistency where a shorter moment arm is incorrectly represented. The correct relationship in equilibrium is established as 2 multiplied by 4/5 equals x multiplied by 3/2, leading to the conclusion that x equals 16/15. Participants emphasize relying on numerical values over the schematic for clarity. Accurate representation of moment arms is crucial for understanding torque in this context.
Laurencio
____
Welcome to PF.
Your diagram is a little confusing because the visualization of the moment arms is inconsistent.
The red is shown shorter when in fact it's moment arm is longer 3/2 > 4/5.
If it is in equilibrium then 2*4/5 = x*3/2 ==> x = 16/15
____
I'd go with the numbers as the schematic is merely a visual aid.
____
