Torque Calculation for Homework Problem
The discussion focuses on calculating the initial angular and linear accelerations of a uniform rod pivoting from a horizontal position. The moment of inertia is identified as 1/3 ML², and the net torque is discussed in relation to the center of mass, which is located at L/2 from the pivot. The participants clarify the application of the parallel axis theorem and its relevance to torque calculations. They emphasize the importance of understanding the relationship between torque, moment of inertia, and angular acceleration. The conversation concludes with a reminder that once the center of mass is established, the calculations can proceed straightforwardly.
jpas
A uniform rod of length L and mass M is attached at one end to a frictionless pivot and is free to rotate about the pivot in the vertical plane. The rod is released from rest in the horizontal position. What is the initial angular acceleration of the rod and the initial linear acceleration of its right end?
\alpha L =a_t
\tau = I \alpha
The linear acceleration is not the same for all points in the rod but the angular acceleration is. So, I must find the angular acceleration and then calculate the linear acceleration on the right end.
I find the angular acceleration through that second equation. I know that the moment of inertia is \frac{1}{3} M L^2 . But how can I calculate the net torque?
My textbook says the net torque is equal to the torque on the center of mass considering it accumulates all the body´s mass? But why is this so?
Can anybody give me a few tips on how to calculate net torques of rigid bodies?
Thank you
The net torque happens at the center of mass from a theorem known as parallel axis theorem. I know this isn't what you want to hear, but for now, just accept and learn that this is the case: the theorem says this is what you do, so this is what you do. So in that case, where would you say the center of mass is?
In general, calculating the torque of a rigid body will be just like this. You find the moment of inertia (this will be given to you unless you want to do a double integral), and the center of mass. Then you use the \alpha I = \tau formula.
Are you sure? Doesn´t the parallel axis theorem simply say:
I_z=I_CM + MD^2
where I_z is parallel to I_CM and D is distance from I_z to I_CM ? What does this have to do with calculating the torque?
It´s in the center of the rod, at a distance L/2 to the pivot.
Hmm, okay, sorry. Maybe I got my theorem's mixed up. You're right though, CM is at L/2. From here, it's plug and chug.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
