Calculating Net Torque on a Circle: 4.0cm Diameter, 20N and 30N Forces
The discussion centers on calculating the net torque on a circle with a 4.0 cm diameter, where a 20 N force pulls down on one side and a 30 N force pulls down on the other. The correct net torque calculation yields -0.2 N m, which the original poster initially misinterpreted due to a potential error in the reference book. Participants confirm that the book likely confused units, as the calculated torque is also equivalent to -20 N cm. It is advised to sum torques individually for accuracy, reinforcing the correct method for future calculations. The conversation concludes with appreciation for the guidance provided.
bigsaucy
Hello all, I am new to the forum so excuse any errors in my posting format
The question is as follows:
There is a circle with a 4.0cm diameter. There is a force of 20 N pulling downwards on the left of the circle and on the right of the circle there is a force pulling down at 30N. The question is to find the net torque about the axle.
I reasoned that the net force acting would be 10N on the right hand side of the circle so therefore using the equation
T = rF
T = (0.02m)(10N) = 0.2 N m
which i converted to -0.2 N m because it is acting clockwise the back of the book however says that the answer is -20 N m
PLEASE HELP, THANKS!
welcome to pf!
hello bigsaucy! welcome to pf! :wink:
your reasoning and answer are correct :smile:
the book must have got confused between cm and m :rolleyes:
Looks like a book error, your answer is correct, the net torque is (- 0.2 N-m) or (- 20 N-cm).
However, although your answer is correct, do not calculate net torques in the manner you have done. Sum torques individually, that is, net torque = 20(0.02) -30(0.02) = - 0.2 N-m.
thanks guys, you lot are great!
and phantom, thanks for the advise, ill be sure to follow your format from now on. thanks heaps!
