What is the correct moment of inertia for a spinning disk?
  • Thread starter Thread starter ac7597
    Disk Flat Torque
The discussion focuses on calculating the torque and new rotation period of a giant spaceship shaped like a flat disk, which experiences a malfunctioning thruster. The torque exerted by the thruster is calculated using the formula torque = |force||radius|sin(theta), yielding components in the î, ĵ, and k̂ directions. Participants clarify the correct moment of inertia for the disk, emphasizing the need to use I = (1/2)mr^2 for a solid disk spinning around its central axis, rather than other formulas that might apply in different contexts. After determining the angular acceleration and adjusting for the initial angular velocity, the new rotation period is calculated to be approximately 197.8 seconds. The conversation highlights the importance of correctly applying physics principles to solve rotational dynamics problems.
ac7597
The Jupiter 6 is a giant spaceship in the shape of a big, flat disk: it has radius R=5000 m, height h=200 m, and mass M=8.00E+08 kg. As it flies through space, it rotates around its center with a period of P=200 seconds to generate artificial gravity. The rotation looks counter-clockwise as seen from above the ship.
One day, one of the outboard thruster rockets malfuctions. It is located at the point marked with a big black dot on the diagram, on the outer rim of the ship, an angular distance θ=30 degrees away from the x-axis. The thruster exerts a force with components 71î +0ĵ −158k̂ mega-Newtons for a duration of t=2 seconds before the technicians can disable it.
What is the torque exerted around the center of the ship by the thruster in the î direction, in the ĵ direction, and in the k̂ direction ?
What is the new rotation period of the ship after the thruster stops firing?
torque= |force||radius|sin(theta)
Since torque= |force||radius|sin(theta) :
î = |71E6||5000m|sin(30)= 177.5E9 N*m
ĵ = |0||5000m|sin(30) = 0
k̂ = |-158E6||5000m|sin(30)= 395 N*m
ac7597 said:
Homework Statement: The Jupiter 6 is a giant spaceship in the shape of a big, flat disk: it has radius R=5000 m, height h=200 m, and mass M=8.00E+08 kg. As it flies through space, it rotates around its center with a period of P=200 seconds to generate artificial gravity. The rotation looks counter-clockwise as seen from above the ship.
Homework Equations: torque= |force||radius|sin(theta)
You're mixing and matching your methods of determining cross products.
It's true that
\vec \tau = \vec r \times \vec F = |r||F| \sin \theta,
but that's only useful if you know what \theta is (the angle between \vec r and \vec F [It's not 30 deg here]), have already calculated the magnitudes of r and F, and even then, you'll still need to calculate a new angle for the one corresponding to \vec \tau. But you haven't done all that yet (I don't recommend using this approach, btw. See below).
[Edit: Actually, I take that back. The force and radius vectors do line up nicely on the x-z-plane. So using the above approach is fine. You'll still need to calculate \theta and the magnitudes of r and F though. That said, I still think that the approach below is probably still easier anyway.]
The above approach is convenient if both the radius and the force line up nicely on a convenient plane like the x-y-plane. But that's not the case here.
Another way to find the cross product (which I do recommend in this case is):
\vec \tau = \vec r \times \vec F =<br /> \begin{vmatrix}<br /> \hat \imath &amp; \hat \jmath &amp; \hat k \\<br /> r_x &amp; r_y &amp; r_z \\<br /> F_x &amp; F_y &amp; F_z<br /> \end{vmatrix}<br />
Your fist order of business then is to calculate the components of \vec r.
Likes Antarres
rx=5000m
ry=5000m
rz=200m
ac7597 said:
rx=5000m
ry=5000m
rz=200m
That point is not even on the ship.
Recall that torque is the cross product of a vector-valued point of application (##\vec{r}##) and a vector-valued force (##\vec{F}##). We are looking for the coordinates of the point of application, ##\vec{r}##.
ac7597 said:
rx=5000m
ry=5000m
rz=200m
As @jbriggs444 mentions, something's not quite right there.
You're looking for the coordinates where the force is applied [relative to the ship's center of mass]. Since the ship's center of mass is at the origin: the coordinates of "the point marked with a big black dot on the diagram."
It might be worth pointing out that the coordinate system defined in the diagram has the y-axis in the "up - down" direction (not the z-axis), as seen from the viewer's perspective. (This threw me at first too in my earlier response, before my edit.)
So the plane of the ship lies mostly in the x-z-plane (not the x-y-plane).
Also, while not specifically indicated, I think it's safe to assume that the thruster rocket lies along the center of the height of the ship (still on the edge of the ship, but in the center of the 200 m height). In other words, I think it's safe to assume that r_y = 0. So that just leaves r_x and r_z to calculate.
Rx = -5000 m
Ry = 0
Rz = -200 m
ac7597 said:
Rx = -5000 m
Ry = 0
Rz = -200 m
No, I think you're just guessing now.
r_x \hat \imath and r_z \hat k are at right angles to each other. It's possible to put them together in such a way that they form a right triangle. The hypotenuse of that right triangle is 5000 m. How does one find the components of such a triangle? (Hint: this is where the 30 deg comes in.)
5000sin(30) = 2500 rx
5000cos(30) = 4330 rz
That's closer to the right idea, but still not quite. (Not to mention It looks like you forgot a couple of "=" signs.)
Look carefully at the diagram. Notice that \theta is defined with respect to the x-axis.
So, does that make r_x the "opposite" leg of the triangle or the "adjacent" leg?
For future reference, recall:
\sin \theta = \frac{\mathrm{opposite}}{\mathrm{hypotenuse}}
\cos \theta = \frac{\mathrm{adjacent}}{\mathrm{hypotenuse}}
\tan \theta = \frac{\mathrm{opposite}}{\mathrm{adjacent}}
rx = 4330
rz = 2500 ?
ac7597 said:
rx = 4330
rz = 2500 ?
Yes! :smile: Correct.
But I think it's important you understand why.
\vec r = 4330 \hat \imath + 0 \hat \jmath + 2500 \hat k \ [\mathrm{m}]
Take that equation and look at the diagram with the disk on it. Follow out each component along the x-axis, y-axis, and z-axis on the diagram. Do you see how that shows the coordinates of the "big black dot"?
If not, try to concentrate on that until you can see it. It may be important for future problems.
This particular problem made it a little easier, because all the values are non-negative here. You might want to ask yourself, "what if \theta was going in the other direction (so there's a component along the negative z direction instead of the positive z). How would that have affected the sign of the components?
Anyway, these are just ideas to help familiarize yourself with 3D vectors.
So, now all that's left is to plug them into
and evaluate.
î = 0 N*m
ĵ = 861.6E9 N*m
k̂ = 0 N*m
Thanks!
I confused on how to find the rotational period. Do I need to find the angular acceleration: torque= (moment inertia) * (angular acceleration). Then use angular acceleration to find the angular velocity : ω1=0+ (angular acceleration)(2seconds). Linear velocity= ω1*radius.
Finally, period=(2*pi*radius)/Linear velocity
ac7597 said:
î = 0 N*m
ĵ = 861.6E9 N*m
k̂ = 0 N*m
Thanks!
Good work! :smile:
Yes, that approach will work fine. But realize, there's no need to go back to linear velocity at this point. Recall that the period T is just the inverse of the simple frequency f.
f = \frac{1}{T}
And the angular velocity (a.k.a., angular frequency) \omega is
\omega = 2 \pi f
A small bit of substitution will easily relate T and \omega.
There's another way to conceptually think about solving the rest of this, although the actual calculations are almost identical to what you described above.
In linear mechanics, the impulse (force times time) equals change in linear momentum.
There is an angular version that you can use here, for this problem:
Torque times time equals change in angular momentum.
But whether you use the angular impulse method here, or the angular acceleration method you described above, you should get the same answer.
Oh, and just to be clear, the torque applied for those 2 seconds will apply a change to the angular velocity. Don't forget it was spinning before rocket misfired (initially, the angular velocity was non-zero). So you'll need to add this new change in angular velocity to the initial angular velocity (rather than add it to 0).
Iy= (1/12)(mass)(3*radius^2 + height^2)
Iy= (1/12)(8*10^8)(3*5000^2 + 200^2)= 5*10^15
torque= 861.6E9 N*m = 5*10^15 *(angular acceleration)
angular acceleration= 172.3 * 10^-6
ω1= 0 + 172.3 * 10^-6 (2second) = 344.6E-6
ω1= 344.6E-6 =2π *f
f=54.8E-6
period= (54.8E-6 )^-1= 18.2 * 10^3 seconds
For some reason this is wrong
ω1= 344.6E-6 =2π *f
f=54.8E-6
Look up the moment of inertia for a solid disk/cillinder spinning around its primary axis. (I think you used one for thin rod)
w0= 2*pi/ (200s) =31.4E-3
correction: ω1= 31.4E-3 + 172.3 * 10^-6 (2second) = 31.76E-3
31.76E-3/(2*pi) = f = 5.05E-3
period = (5.05E-3)^-1 = 197.8 seconds
Iy= (1/4) (mass) (radius) ?
Isn't there a height for the disk?
Hold, on. Could you step back a bit and walk me through it. Something is really wrong with the Moment of Inertia formula that you used.
(Hint: the 200 m height of the ship is irrelevant. If you're using that in your calculations somewhere then something isn't right.)
From what I gather from the problem statement, you are supposed to treat the ship as a solid disk.
Here is a useful link for moments of inertia:
https://en.wikipedia.org/wiki/List_of_moments_of_inertia
Okay, I see what you did.
Pay close attention to which axis the disk is spinning. The disk is spinning around its central axis -- the one that has cylindrical symmetry.
You were using an axis as through it's tumbling top over bottom. That's not the axis you want here.
Iy= (1/4)(mass)(radius^2)
Iy= (1/4)(8*10^8)(5000^2)= 5*10^15
I got the same answer even if I used either the Iy= (1/4)(mass)(radius^2) or Iy= (1/12)(mass)(3*radius^2 + height^2)
The moment of inertia formula is not (1/4)(mass)(radius^2) for a spinning disk, spinning about its axis of [cylindrical] symmetry.
I confirmed that 197.8s is correct
The correct moment of inertia of a disk depends on which axis it is spinning.
If a solid disk spins like a normal wheel on a car, a record on a turntable, or pretty much any disk that you would imagine spinning like a normal disk, its moment of inertia is
I = \frac{1}{2}mr^2
On other other hand, if you grab a disk by its edges, with one hand on one side and the other hand on the other side of the disk, and you use your fingers to spin it end over end, then its moment of inertia is
I = \frac{1}{12}m \left(3 r ^2 + h^2 \right)
But that's not the moment of inertia that you want in this problem.
For this problem you want to use the I = \frac{1}{2}mr^2 formula. The spaceship disk is initially spinning normally (like most disks do). And when the torque is applied it doesn't change that. The torque is applied on the same axis as the initial rotation.
If you used either
I = \frac{1}{4} mr^2
or
I = \frac{1}{12} m \left(3 r^2 + h^2 \right)
then you got the wrong answer. An online automated program might have "accepted" the answer to be within reasonable limits, but it's still technically wrong (I imagine the program would have accepted any answer near 200 seconds).
