Torque on a hinge to a gate that is 69 inches long
To lift a 69-inch gate that requires 50 lbs of force at a little over a 90-degree angle, the torque needed can be calculated using the formula torque = force x distance. Given the length of the gate, the torque required would be 50 lbs multiplied by 69 inches, which equals 3450 inch-pounds. To offset the majority of the weight, a torsion spring must provide a torque close to this value. A free body diagram would help visualize the forces acting on the gate and the spring's placement. Proper calculations and diagrams are essential for determining the exact specifications needed for the torsion spring.
ewhite17
I have a gate that is 69 inches long and it takes 50 lbs of force to lift at the end of the gate when it is extended at a little over a 90 degree angle. How many foot pounds of torque in a torsion spring will be needed to lift the gate or at least offset the majority of the weight?
Draw a free body diagram.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
