Torque on a loop within a solenoid?
The discussion focuses on calculating the torque on a rotating loop within a solenoid. The solenoid has a radius of 100mm, a turn density of 5 turns/mm, and carries a current of 10 Amps. The loop, with a radius of 15mm and 25 turns, carries 2 Amps and is oriented normal to the solenoid's axis. The magnetic dipole moment is calculated as 0.03535, and the magnetic field inside the solenoid is derived using the formula B = (μ₀)(n)(I). The final torque is determined to be approximately 2.22 x 10^-3 N·m.
roccofitz
Question:
A solenoid has of radius 100mm and turns density of 5 turns/mm has a current of 10 Amps flowing in it. There is a loop of radius 15mm and 25 turns within the solenoid. The loop is free to rotate about an axis which is normal to the axis of the solenoid. Determine the torque on the loop when there is 2 Amps flowing in it and its plane is normal to the cross sectional plane of the solenoid.
magnetic dipole moment mu=NIA
N= number of turns
I=current
A=area
torque=mu X B X=cross product
mu =(25)(2)(7.07x10^-4)
mu= 0.03535
I can get the magnetic dipole moment in the loop but after that I am stuck??
Use the expression for the torque that you posted. What is B inside this solenoid?
That is where I am stuck, I know a formula for B is F=BILsin theta but I don't see how this would work? This is the full question but I've no idea how to get the answer.
No, that's not the formula for B. You need the formula for the B field inside the solenoid that looks like
B = (A whole bunch of stuff that is given to you by the problem)
Look it up in your textbook or the web.
Or better yet, use Ampere's Law to get B yourself. It's great practice, if you don't have much of a handle on using it yet.
Ok here's my new attempt right or wrong??
Relevant Equations:
N=number of turns
I=current
A=area
B=magnetic field= (mu_0)(n)(I)
mu_0=magnetic constant
n=turns density
I=current
Attempt:
mu= 0.03535
B=4pi10^-7(5000)(10)=1/50pi
torque=mu X B= muBsin(theta)
I think thetha =90 as the loop is normal to the solenoid axis
therefore torque =muBsin(90)= 0.03535(1/50pi)sin90= 2.22x10^-3 N.m
That looks about right.
Thank you for all the help :)
