Torque required to prevent precession
  • Context: Undergrad
  • Thread starter Thread starter rcgldr
    Precession Torque
This discussion focuses on quantifying the torque required to prevent precession in a spinning gyro, specifically when a torque is applied about the x-axis while the gyro spins about the z-axis. The conversation highlights that the frame must exert an equal and opposite torque to negate the applied torque, preventing rotation about the y-axis. The participants clarify that the gyro is not affected by gravity, and they reference the relationship between angular momentum and torque in this context. The discussion also touches on historical examples and videos illustrating these principles.
  • Understanding of gyroscopic motion and precession
  • Familiarity with Newton's third law of motion
  • Knowledge of angular momentum and torque relationships
  • Basic principles of rotational dynamics
  • Research the mathematical formulation of torque in gyroscopic systems
  • Explore the effects of external forces on gyroscopic stability
  • Study real-world applications of gyroscopic precession in engineering
  • Investigate historical experiments demonstrating gyroscopic behavior
Physics students, mechanical engineers, and anyone interested in the dynamics of rotating systems and gyroscopic applications.
rcgldr
Homework Helper
TL;DR
A torque is applied to a spinning gyro, and a second torque is applied to prevent precession. How to quantify the second torque?
Example, a gyro spinning about the z axis is connected to a frame that can only rotate about the x axis. A torque about the x-axis is applied to the frame. What is the torque about the y-axis exerted onto the frame by the gyro and its Newton third law counterpart, the torque the frame exerts onto the gyro about the y axis, that prevents the gyro from precessing? The rate of change in angular momentum about the x-axis would be due to the combined external torques.
rcgldr said:
Summary: A torque is applied to a spinning gyro, and a second torque is applied to prevent precession. How to quantify the second torque?
Are we to assume that this gyro is not affected by gravity?
Since there is a constant torque about the x axis, the torque vector is a constant vector along the x axis. As a result, if the frame was free to move about all axes, the change in the angular momentum vector would be: ##d\vec{L}=\vec{\tau}dt## ie the change in angular momentum is in the direction of the x axis.
The resultant of ##\vec{L}+d\vec{L}## would be a new ##\vec{L'}## in which the axis of spin has rotated about the y-axis at an angle to the z axis ##\alpha## such that ##\alpha=\frac{\vec{\tau}dt}{\vec{L}}##.
But that cannot occur, because rotation about the y-axis is not allowed. So it seems to me that the frame must apply a torque to the x-axis that is equal and opposite to the applied torque along the x-axis to negate that applied torque.
AM
The gyro in question is not affected by gravity.
The frame is free to rotate about the x-axis, so how does it generate a torque about the x-axis?
I recall some video where with the same or similar configuration: if rotation about y-axis is blocked, the reaction is the gyro accelerates about the x-axis as if the gyro was not spinning, no angular momentum, just angular inertia.
I haven't been able to find that video again, but I did find this old (1974) example claiming that there is no angular momentum related to precession. I set the link time to where an 8 lb gyro supported at one end is spun up to several thousand rpm and is precessing (with assist to get it near level) due to torque from gravity, then a small peg is placed in a hole that blocks the other end, stopping the precession, and the gyro just drops down (and bounces back a bit). The support structure is then vertically oriented, but there's too much play in the hole, so the peg moves instead of breaking. In another part of the video, a false claim is made about assisting the precession affects the downwards force at the support, but any movement in the supporting spring is probably nutation.
  • · Replies 49 ·
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 30 ·
  • · Replies 19 ·
  • · Replies 39 ·
