Torque value needed to move a particular vehicle
To move a 200kg vehicle to 30 km/h with a 24V, 250W DC motor, a torque of approximately 60 Newton meters is required, considering an acceleration of 1.3 m/s² and a low coefficient of friction of 0.02. The total force needed to overcome rolling resistance and achieve this acceleration is about 30.5 kgf. However, sustaining this acceleration up to peak speed would demand around 2500 watts, far exceeding the motor's capacity. In comparison, a Tata Nano, weighing 680kg, requires only 51 N-m of torque to reach 60 km/h in 10 seconds, highlighting the differences in power requirements between electric and internal combustion engines. Understanding these dynamics is crucial for evaluating vehicle performance and motor specifications.
naeem shaik
can i know how much torque is required to move a 200kg weighed vehicle to 30kmph by using 24v, 250w dcmotor
Welcome to Physics Forums
The answer depends on how much acceleration and how much friction. You did not supply enough information for us to answer.
acceleration: 1.3m/s2
coefficient of friction: 0.02
wheel radius:8inch
OK, I'm rusty but I'll take a crack.
Acceleration ##F = m*a = 1.3 m/s^2 * 200 kgm = 260 Newtons = 26.5 kgf##
Rolling resistance ##200 kgf * 0.02 = 4 kgf## (assume air resistance is zero)
Total force, ##30.5 kgf##
The wheel radius is 8" or 0.2 m.
Torque = ##30.5 kgf * 0.2 m = 6.1 kgf*m = 60 n*m##
60 Newton meters torque is my answer.
The fact that torque is supplied by a motor is irrelevant.
If the acceleration is maintained all the way up to the peak speed of 30 km/h (8.3 meters/sec) then that's 300 Newtons times 8.3 meters/sec ~= 2500 watts. That's an awful lot to expect from a 250 watt motor.
If we assume, instead, that we are just supplying the 40 Newtons required to match rolling resistance then that's 40 Newtons times 8.3 meters/sec = 333 watts. That's still going to be pretty tough on the motor even without factoring in air resistance.
i noticed for tata nano car (i c engine) weighing 680kg needs only 51 n-m torque to accelerate to 60kmph in 10 sec can we compare the both in the case of torque required
IC Motor specs are generally given at the flywheel so any gearing is ignored. The torque value at the engine means little as it can be easily changed with the gear box. What matters is power output as, ignoring drive train losses, power is constant for any gear/wheel size/final drive etc
thanks for your help
