Maximizing Projectile Distance with Torsion Spring Catapult
To determine the maximum distance a one-ounce projectile can be launched with a torsion spring catapult, it's essential to understand the relationship between force, distance, and energy. The equation E = F * d is applicable, but it requires integration due to the variable nature of force with angle changes. The torsion spring's force at the end of the arm is critical, and it is confirmed that the force drops to zero below 140 degrees. The length of the arm, measured at 0.17145 meters, plays a significant role in calculating the energy imparted as the angle changes. Understanding these dynamics is crucial for accurately computing the projectile's launch distance.
Berwin
Determine maximum distance an one ounce projectile can be launched with a torsion spring catapult.
E = F * d = 1/2 * m * v02Note: Theta is the measurement of how far the lever arm is being pulled back.
Am I missing something?
There does not appear to be enough information, in two ways.
There's no basis for figuring the distance through which the force acts. It doesn't say what the force is for smaller angles. It could be linear down to about 10 degrees, or it might suddenly drop to zero somewhere below 140.
But your equation E = F * d is only valid for constant forces, which this clearly is not. The more general form requires you to integrate F over the distance. If the force is a linear function of distance over the range of integration (which it looks to be from the table) then the result will be quadratic.
If it helps at all, the torsion spring in this case is one you find in a mousetrap. We've attached a plastic spoon to the lever arm of the mousetrap, which together reach 0.17145 meters. Does this make a difference?
That's useful info. So as the arm moves through angle dθ, the force advances rdθ, where r = 0.17145 m. That allows you to calculate the energy imparted as the angle changes.
However, just realized I should have checked something. The F values in the table really are the force at the end of the arm, yes? They're not torque (Nm)?
That leaves the question of whether the table is complete. I.e., as the angle falls below 140o, does the force suddenly vanish or does it continue to decline linearly?
Yes, it's just the force at the end of the arm. The force suddenly vanishes. We only wanted to test the angles given above in the chart.
Ok, so do you understand how to compute the total energy from that chart (combined with knowledge of the length of the arm)?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
