Is Gravity Always Negatively Affecting a Ball?
In summary, When an object is tossed, it experiences a constant negative net force due to the equation F=ma where acceleration is always negative. The convention for down being negative is used. For an object moving in the xy plane with equations x=-(5.00m)sin(ωt) and y=(4.00m)-(5.00m)cos(ωt), the components of velocity and acceleration can be found by taking the derivative and second derivative of the equations. The notation of seconds^-1 can be used when finding the derivative of x, which is represented by the omega symbol. The velocity vector is represented by \vec{v} = v_{x} \hat i + v_{y} \hat j
  • #36
Well graph for the trajectory, use y and x. assign values to t. then explain how it moves... should look like a sinusoidal or cosinusoidal.
  • #37
I think they want me to describe the movement of the object...which is just like a sine curve right? A bouncing ball basically
  • #38
Yes, basically :smile:
  • #39
how would I know if it was sinusoidal or cosinusoidal?
  • #40
At t=0 sinusoidal starts at 0, and cosinusoidal starts at Amplitude. In this case 1 multiplied by the 5w.
  • #41
Okay, I have one more problem. You're a great help, seriously. I can't get though physics without PF...anyways. There's a fish that is swimming in a horzontal plane. It has an initial velocity of vi=(4.00i+1.00j)m/s at a point in the ocean whose displacement from a certain rock is r=(10.0i-4.00j)m. After the fish swims with constant acceleration for 20s, it has a v=(20.0i-5.00j) m/s. The componet of acceleration would be...
x=(4.00i-20.0i)/20s
y=(1.00j-(-5.00j))/20s
something like this? acceleration is the change in velocity over change in time...am I heading in the right direction?
  • #42
It's Final Speed - Initial Speed.
  • #43
x=(20.0i-4.00i)/20s
y=(-5.00j-1.00j)/20s
ai=0.8m/s^2
aj=-0.3m/s^2
is this correct?
  • #44
It is correct.
  • #45
so...if the fish swam for 25 seconds...to find its position relative to the rock @ r=(10.0i-4.00j) is to use
di=vit+.5at+xi
di=4.00(25)+(.5)(0.8m/s^2)(25s)+10
di=120
so do the same for dj
is this correct?
  • #46
Incorrect, the time accompanying the acceleration goes squared.
  • #47
di=vit+.5at^2+xi
di=4.00(25)+(.5)(0.8m/s^2)(25s)^2+10
di=360m
  • #48
It is correct.
  • #49
The componet for velocity is x’= -(5.00m) ω cos ωt and y’= (5.00m) ω sin ωt
At t=0 seconds, x’= -(5.00m) ω and y’=0m/s
The componet for acceleration is x’’=(5.00m)ω^2 sin ωt and y’’= (5.00m) ω^2 cos ωt
At t=0 seconds, x’’=0m/s^2 and y’’=(5.00m)ω^2
  • #50
I was going to suggest working these parametric equations into one whole equation and examine that in the cartesian coordinate system.
  • #51
I just started this chapter and do not understand a lot of this...like the cartesian coordinate system
  • #52
[tex] x=-(5.00m) sin \omega t [/tex]
[tex] y=(4.00m)-(5.00m)cos \omega t [/tex]
We could square the x expression so
[tex] x^2=(25.00m) sin^2 \omega t [/tex]
then apply the pythogoras identities
[tex] x^2=(25.00m) (1 - cos^2 \omega t) [/tex]
[tex] x^2=(25.00m) - (25.00m) cos^2 \omega t [/tex]
[tex] (25.00m) - x^2 = (25.00m) cos^2 \omega t [/tex]
[tex] \frac{(25.00m) - x^2}{(25.00m)} = cos^2 \omega t [/tex]
[tex] \sqrt{\frac{(25.00m) - x^2}{(25.00m)}} = cos \omega t [/tex]
Substitute in the other
[tex] y=(4.00m)-(5.00m)\sqrt{\frac{(25.00m) - x^2}{(25.00m)}} [/tex]
Evaluate this graph, i think it will be better.
  • #53
Well i graphed it in my calculator, i guess i was wrong, looks like a circle, i was thinking about it too, looked like an elipse expression for a polar coordinate, I'm not sure about the path. In the cartesian it forms an arc.
  • #54
I'm trying to understand what you did, is this relating my first problem or my second problem?
  • #55
I asked a friend (mathematician) he says it will form a cardiode in a polar, and half a circle in cartesian, that should be the path, i don't know how to explain it to you.. but i think the question asked maybe requires a simpler solution, and i must had misunderstood it.
  • #56
wow, that is WAY beyond me. What question were you trying to answer?
  • #57
The trajectory, if you want put an asterisk next to it, see what your teacher says.
  • #58
This is all I did:
x=-(5.00m) sin ωt
x=-(5.00m) sin ω(0)
x=0m
y=(4.00m) – (5.00m) cos ωt
y=(4.00m) – (5.00m) cos ω(0)
y= (4.00m) – (5.00m) = 1.00m
The path of the object would represent a sine cure. The x position would start at zero while the y position would start at 1m.
  • #59
Its path is half a circle actually... Like my friend said. I was wrong about the sine curve.
  • #60
so it's like a parabolic arc? Not quite sure how I could describe this.
"The ball will bounce like a parabolic arc"?
  • #61
Yea, it seems.
  • #62
Could you check if I did this correct...
  • #63
Looks ok to me.
  • #64
I wasnt sure if the omega symbol needed to be included in the answer or not, just checking
