Calculating Total Force on Earth from Venus, Jupiter, and Saturn
  • Thread starter Thread starter ObviousManiac
    Earth Force
The discussion focuses on calculating the total gravitational force on Earth from Venus, Jupiter, and Saturn, assuming they are aligned. The user initially struggles with determining the distances between Earth and the other planets, given their distances from the Sun. By subtracting the distances, they correctly find the distances to Venus, Jupiter, and Saturn. The gravitational force is calculated using the formula F = Gm1 m2/r^2, and the user realizes that the force from Venus should be considered negative due to its direction. Ultimately, the correct total force on Earth is determined to be 9.03×10^17 N.
ObviousManiac
Calculate the total force on the Earth due to Venus, Jupiter and Saturn, assuming all four planets are in a line (see figure).
An amateur astronomer measures the masses to be MV = 0.888 ME, MJ = 324 ME, MS = 98.0 ME, and their distances from the Sun are 1.080×10^8 km, 1.500×10^8 km, 7.780×10^8 km and 1.430×10^9 km respectively.
The mass of the Earth ME is 5.980×10^24 kg and the distance from the Earth to the sun is 1.500×10^8 km. The mass of the sun is 1.99×10^30 kg.
F = Gm1 m2/r^2
My problem is how to calculate the distance from each planet to earth. Like, if both Earth and Jupiter are 1.500x10^8 km from the sun, how far apart are they?
so you've got five points on a line
Sun Venus Earth Jupiter Saturn
you know the distance from the Sun to each of these points
From that you can know the distance between two of the points by subtracting the shorter distance from the longer one. For instance: the distance between Jupiter and Saturn would be found to be the distance from the Sun to Saturn minus the distance from Jupiter to Saturn.
You might be able to see it more clearly if you draw out a picture of the situation. Don't worry about making it to scale.
Okay, so:
Distance from Earth to corresponding planet:
Venus = 1.500×108 km - 1.080×108 km = 42,000,000 km = 4.2E10 m
Jupiter = 7.780×108 km - 1.500×108 km = 628,000,000 km = 6.28E11 m
Saturn = 1.430×109 km - 1.500×108 km = 1,280,000,000 km = 1.28E12 m
F = GME[(.888ME/(4.2E102) + (324ME/(6.28E112) + (98ME/(1.28E122)]
F = GME[(3010.3 + 4912.8 + 357.7)
F = GME(8280.8) = 3.3E18 N
...but I still get the answer wrong. Any help? Would the force from Venus be negative because it's in a different direction than Jupiter and Saturn?
haha answered my own question there - I set the (3010.3) to be negative and that gave me the right answer. Thanks for the help!
btw for anyone wondering the correct answer is 9.03×10^17 N
