Total Internal Reflection a doubt?
The discussion revolves around the concept of total internal reflection as it relates to mirrors, with a focus on the nature of reflections and refractions occurring within the mirror. Participants explore whether 'weak refractions' exist and how many times total internal reflection occurs in a given scenario.
  • One participant questions the existence of 'weak refractions' in the context of total internal reflection in mirrors.
  • Another participant suggests that the example discussed may actually involve "partial internal reflections" rather than "total internal reflections," indicating a distinction based on the angle of incidence.
  • A sequence of reflections and refractions is proposed, detailing the interactions of light within the mirror, including reflections off the silvered surface and partial internal reflections that lead to light emerging from the mirror.
  • A participant notes that in practical scenarios, multiple internal reflections may occur due to the parallel surfaces of mirrors, drawing a comparison to fiber optic cables.
Participants do not reach a consensus on whether the reflections discussed are total or partial internal reflections, indicating a disagreement on the interpretation of the phenomenon.
The discussion includes assumptions about the angles of incidence and the nature of reflections and refractions, which remain unresolved. The distinction between total and partial internal reflection is not fully clarified.
Individuals interested in optics, particularly those exploring the behavior of light in reflective surfaces and the principles of internal reflection.
archijun3
I was reading about a case of total internal reflection in mirrors and something got me curious...
Is there anything such as 'weak refractions'??
In the diagram of the mirror I saw, as a ray of light from an object entered a mirror, it was reflected by the silver coating, and then by the surface of the mirror (assuming it's because of total internal reflection). This process was repeated three times more, and the light ray emerged out of the mirror.
The doubt I have here is, everytime the ray of light was reflected off from the surface of the mirror (total internal reflection), there was a ray of light exiting the mirror at that point. Where exactly did that ray of light come from?
Plus, if I may ask further, how many times will total internal reflection have taken place in the above situation?
Science news on Phys.org
I believe the example you are looking at is demonstrating "partial internal reflections" not "total internal reflections".
See the diagram below (from.. http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/totint.html).
On the left the angle of incidence is such that the light is partly relected and partly refracted.
As the angle changes there is a point at which the light that emerges is refracted along the surface. This is called the critical angle.
On the right the angle is such that the light is totally reflected and no light emerges.
I make the sequence..
A refraction
A reflection off the silvered surface
A partial internal reflection (some light emerges)
This is then repeated three more times..
Because the very last reflection is partial there will be a faint emerging ray which is the one you describe as leaving the mirror.
In the real world you would probably get a lot more internal reflections because mirrors have parallel surfaces. That means once the ray is bouncing around between the surfaces the angle of incidence doesn't change much so there is nothing but the edge of the mirror to stop internal reflections. That's more or less how crude fiber optic cables work.
My thanks to CWatters :)
So this is an example of partial internal reflection isn't it??
I was confused because the heading was written as total internal reflection..zz
It's been a great help xD Thank you!
  • · Replies 17 ·
