Calculating Total Momentum of Objects Moving in Different Directions
  • Thread starter Thread starter ckaiser813
    Momentum
To calculate the total momentum of objects moving in different directions, it's essential to treat momentum as a vector with components in each direction. For the given scenario, the momentum of the 4.00 kg ball moving north is calculated using its mass and velocity. The 5.00 kg ball moving northwest requires breaking its velocity into components to find its northward and westward momentum. The total momentum in the north direction combines the contributions from both balls. Understanding vector addition is crucial for accurately determining the total momentum of the system.
ckaiser813
A 4.00 kg ball is moving at 3.00 m/s to the NORTH and a 5.00 kg ball is moving at 2.00 m/s to the NORTHWEST. The total momentum of the system is:
I have a very bad book that doesn't discuss how to deal with total momentum with relationship to different directions other than head on, would just like for someone to explain the way to set up my formula to find this one.
Hi ckaiser813,
Momentum is a vector, and it has one component for each of the three perpendicular directions. For example, here's how you find the momentum in the north direction. If ball one has a velocity v in the north direction and has mass m, and if ball two has velocity w in the north direction and mass M, then the momentum in the north direction is mv + Mw.
Thread 'Correct statement about a reservoir with outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
