Tracking Distance on one Axis with an Accelerometer
The discussion focuses on using an accelerometer to track distance on one axis for a rocket project, despite acknowledging that there are better methods available. The initial approach involves calculating speed and distance based on acceleration readings over time intervals. A key point raised is that the "New speed" calculated represents the speed only at the end of the interval, which could lead to inaccuracies. A more accurate method suggested involves averaging accelerations and velocities at the ends of the interval to improve calculations. The conversation emphasizes the importance of precision in tracking distance using accelerometer data.
ferret_guy
I need to track Distance on one Axis with an Accelerometer for a rocket project (i know there are bettor ways t do this but i am dead set on this one) I was thinking as follows,
Code:
Read Accelerometer
Accelerometer*Δt=Δv
Current speed+Δv=New speed
distance+New speed*Δt=New distance
Isn't "New speed" the speed only at the end of the interval "delta t", not for the whole duration of delta t?
This function is repeated many times so that is the speed that is dirived from the inatil meshurment and the Δt is the time since the last meshurment so were assuming that your travling at a constant speed for the time it takes to exicute the pice of code
Yes. It will still work, but is inaccurate. A better simple method is averaging accelerations and velocities at the ends of the interval:
PHP:
velocityX[0] = 0 // we assume the device was static when we started recording acc
positionX[0] = 0
for every sample i > 0:
    dt = time[i-1] - time[i] // if sampling rate is constant simply use 1 / frequency here
    velocityX[i] = velocityX[i-1] + (accX[i] + accX[i-1]) / (2 * dt)
    positionX[i] = positionX[i-1] + (velocityX[i] + velocityX[i-1]) / (2 * dt)
Better is:
http://doswa.com/2009/01/02/fourth-order-runge-kutta-numerical-integration.html
Thank you I was hesitant about posting code because I dident know how many people wold be able to interpret it
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
