What Are the Steps to Calculate Vc, Vb, and Ve in a Transistor Circuit?
  • Thread starter Thread starter dawsonss
    Transistor
To calculate Vc, Vb, and Ve in a transistor circuit, it's essential to clearly define the problem and provide relevant details. The discussion highlights the importance of understanding the voltage divider configuration and its impact on the transistor's operation. The quiescent point has been calculated, and simulations suggest it is accurate. Participants emphasize the need for a clear statement of the problem to facilitate effective assistance. Basic knowledge of transistor parameters is assumed for accurate calculations.
dawsonss
transistor problem, helpp!
[PLAIN]https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc6/270474_2182563849439_1407242959_2536426_5250645_n.jpg
how to answerr? thanks
Im sorry but 90% that no one here understands that language. And please make a CLEAR statement what is the problem. I cannot conclude from the picture what's going on, and even if I could, you still should have typed in the problem.
Its the least you can do if you are already asking for help, giving a clear statement what seems to be a problem.
sorry language problems, edited my questions..
http://www.hizliupload.com/img/81836689442763213204.jpg
I calculated the quiescent point for your transistor. It should be ok, my simulations confirmed this somewhat.
In first 2 steps what I did is I split the voltage divider into 2 sources powering transistor on their own. This doesn't change anything in problem.
Also I flipped the picture. So emitter is bottom now.
You are asking Vc, Vb, Ve. I think you should have this basic knowledge of figuring out these parameters from these results.
bass
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
