What Is the Cost to Operate a Transistor Radio for 300 Hours on Household Power?
  • Thread starter Thread starter wakefreak90
    Transistor
The discussion centers on calculating the cost to operate a transistor radio for 300 hours using both battery power and household electricity. The battery costs $0.55 and provides a cost of approximately $3.82 per kWh. For household operation, the radio consumes 518,400 J over 300 hours, translating to 0.144 kWh. At a rate of 6 cents per kWh, the total cost to operate the radio for 300 hours is about 0.86 cents. The calculations emphasize the importance of unit conversions and proper energy measurement.
wakefreak90
**Transistor radio/kWh problem**
A transistor radio operates by means of a 10.0 V battery that supplies it with a 48 mA current.
(a) If the cost of the battery is $0.55 and it lasts for 300 h, what is the cost per kWh to operate the radio in this manner?
3.819 dollars/kWh
(b) The same radio, by means of a converter, is plugged into a household circuit by a homeowner who pays 6¢ per kWh. What does it now cost to operate the radio for 300 h?
? cents
I got Question A but I have tried everything on Question B and I do not understand what I am doing wrong. For some reason, I think it is easier than what I'm trying to do.
Please help!
Work out the number of kilowatt hours and multiply by 6.Note that the question gives the current in mA and not A and note also the the power must be expressed in kW and not W.
So if one kWh = 3.6E6 J, and the total energy is 518,400 J..
(3.6E6)/(518400) = 6.9444
--> (6.9444)(6) = 41.666
Is 41.666 cents the answer? I only have two more tries left and I don't want to get it wrong. I'm not sure if those are the correct unit conversions
W=10*48/1000
kW=above/1000
kWh=above*300
cost=above*6
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
