Calculating Applied Forces and Weld Breakage in Horizontal Rod Suspension
  • Thread starter Thread starter heyjude619
    Forces
To determine the force applied to the weld and the force translated in bending the shaft, the rod can be modeled using lever equations, treating the rod and base as rigid. When a force of 25 pounds is applied at a point 1 inch from the weld, the effective force at the weld can be calculated based on the distances from the pivot point at B. The force exerted on the weld will depend on the leverage created by the distance from the application point to the weld. The exact calculations will vary based on the specific modeling approach chosen for the rod's structure. Understanding these relationships allows for replication of the process with different variable data.
heyjude619
Let’s say I have a horizontal rod whose total length = ΔXtotal = 5 inches. However, the rod is made up of two pieces (ΔXshaft = 4 inches and ΔXbase = 1 inch) that are welded together, where ΔXtotal = ΔXshaft + ΔXbase and where ΔXshaft > ΔXbase. This rod is horizontally suspended in air by locking mechanisms placed at each end of the total length of the rod.
I want to use a force gauge to bend the shaft at a certain point so that the weld that joins ΔXshaft and ΔXbase breaks. For example, let’s say the weld breaks when I apply 25 pounds to a point on the shaft 1 inch away from the weld (so 5-1=4 inches from the secured end of the shaft).
How much force was applied to the weld and how much force was translated in bending the shaft? I would like to see the applicable equations so I can replicate this process with variable data.
A rod is fixed at points A and B.
Point A is at x=0, B is at x=+5"
The base is in 0<x<1"
The shaft is between 1"<x<5"
Let the y direction be "upwards".
If you apply a force F in the -y direction at x=1" away from the base - then the force is pllied at position x=2" or 3" from point B which is the secured end of the shaft.
The exact relations depends on how you want to model the rod.
Back-of envelope - treat the rod and base as rigid and use the lever equations.
Point B is the pivot and the shaft is the lever. The weld position is where you want the effective force.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
