Translational equillibrium calculation when forces acting not at COG
In the discussion about translational equilibrium, it is clarified that the location of forces does not affect the overall translational motion, allowing for simplification by assuming all forces act at the center of mass (COM). The scenario involves a 3m by 3m sheet with two forces acting at corners: a 10 N force to the left and a 20 N force downward. To achieve equilibrium, a third force (F3) must be applied at the COM, calculated to have a magnitude of 10√5 N and directed at an angle of 26.56° with the vertical. The conclusion emphasizes that the rotational effects of forces acting away from the COM can be disregarded for translational equilibrium analysis. Understanding this principle is crucial for solving similar problems in physics.
bubsy
I have a question about translational equilibrium.
Consider a 3m by 3m sheet on the x-y plane. The center of mass is at the origin.
Force-1 of 10 N acts on the top left corner of the sheet and points left.
Force-2 of 20 N acts on the bottom right corner of the sheet and is directed downwards.
Force-3 of yet to be determined magnitude and direction, acts on the center of mass. I need to find the magnitude and direction of this force that will result in the sheet being in translational equillibrium.
I can do this problem if Force-1 and Force-2 acted on the center of mass, but in this case the first 2 forces act on corners of the sheet.
Does it matter that the first 2 forces are not acting on the center of mass? Is the problem equivalent if I promote the first 2 forces to act on the center-of-mass?
Thanks
In terms of translation it doesn't matter where the forces act, the only thing that will change if you apply your force on a different part of the shape is the amount of rotation so for this problem you can just pretend they are all acting on the COM :)
Thanks
jhamm is absolutely right.in translational motion you can just always assume that the forces act on the COM.
proceed and you will find that the force F3 must act on the COM at an angle of 26.56° with the vertical and a magnitude of 10√5 N.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
