Transverse wave particle speeds
The discussion revolves around calculating the maximum and minimum speeds of particles in a transverse wave represented by the equation D = 0.38sin(5.1x+30t). Participants clarify that the correct approach involves taking the derivative of displacement with respect to time, not position. The maximum speed is calculated as 11.4 m/s, but there is uncertainty about the minimum speed, with some confusion regarding the values of the cosine function. Participants suggest that the homework program may have errors, leading to discrepancies in the accepted answers. Overall, the conversation emphasizes the importance of proper differentiation in wave mechanics.
itryphysics
A transverse traveling wave on a cord is represented by D = 0.38sin(5.1x+30t) where D and x are in meters and t is in seconds. Determine maximum and minimum speeds of particles of the cord.
First derivative
I took the first derivative with respect to x
dx/dD = (5.1) .38cos(5.1x+10t)
cosine's max value is at 1 so i set cos(5.1x+30t) = 1
then I solved : (5.1)(.38)(1) = 1.94 m/s
Im not sure if this is right. All help will be appreciated.
Firstly let's clear up some notation.
\frac{dD}{dx}
represents the derivative of D with respect to x.
Secondly, why are you taking the derivative with respect to x?
yes sorry that was honestly a typo. but thank you.
I was taking the derivative with respect to x because of speed's definition. so i thought by taking it with respect to x instead of time, i wud be getting the rate of change of distance...
But the definition of speed is the derivative of displacement with respect to time? Why would you want to find the derivative of amplitude with respect to displacement?
ok thank you for clearing that up. it makes sense now. so apart from the confusion in the derivation, the way i solved the problem ,is that still the route i will take to solve it?
Yes, differentiating D with respect to time will give you the velocity of a particle on the cord at position x and time t.
A word of warning when finding the minimum speed: note that the minimum value of cosine does not correspond to the speed.
Wouldnt the minimum speed be 0?
and when i take the derivative with respect to t, i calculate the v as 30(.38) I am getting 11.4 m/s. However, the homework program is not accepting it as the correct answer. Any more suggestions?
Yes, that was the point I was making. The minimum value of cosine is -1, but this corresponds to the maximum rather than minimum speed, but it looks like you've already got it figured out.
Care to elaborate on your attempt? It's difficult to see where you're going wrong without seeing your solution.
sure. D = 0.38sin(5.1x+30t)
so dt/dx = (30)(0.38)cos(5.1x+30t)
and again since we obtain cosine's max value at 1 i am setting cos(5.1x+30t) = 1
hence ===> (30)(.38)(1) = 11.4 m/s
I guess the derivative has a glitch in it somewhere..please let me know
Except for your notation (dt/dx => dD/dt), your solution looks fine to me.
oops, thank you again. My only bet is that the homework may have been programmed incorrectly.
Thanks for the help mate.
No worries.
