Triangle innequality proof question
  • Thread starter Thread starter transgalactic
    Proof Triangle
transgalactic
for "a" and "b" are real numbers prove that:
http://img352.imageshack.us/my.php?image=34860604zw7.gif
i need to use the triangle innequality
|a|-|b|=< |a+b| <= |a| + |b|
how to apply it to my question?
it a long way from
triangle innequality formula to the expression that i was given in the question
The triangle inequality reads
|x+y|<=|x|+|y|
or
|x|>=|x+y|-|y|
for any two vectors x,y
Take in particular
x=a-b, y=b
and
x=b-a, y=a
What do you get?
Then use, |a-b|=|b-a| and the fact that if |a-b| is greater than c and greater then -c, it must be greater than |c|. (What is c?)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
