How can I simplify commutators with a useful trick?
  • Thread starter Thread starter Fys
    Commutators
Fys
\left[L_{x},L_{y}\right]=\left[yp_{z}-zp_{y},zp_{x}-xp_{z}\right]<br /> =\left[yp_{z},zp_{x}\right]-\left[zp_{y},zp_{x}\right]-\left[yp_{z},xp_{z}\right]+\left[zp_{y},xp_{z}\right]<br />
How next?
My book is not of much help
I Tried
\left[A,BC\right]=\left[A,B\right]C+B\left[A,C\right]
But that is too much work
Does anybody knows a useful trick or something
not only for this case, but for al commutators
Thanks guys
Sometimes you must do the hard work. It depends from case to case regarding what trick you can use, no gereneral rule.
But the general formula for angular momenta commutators is:
[J_i , J_j ] = i\hbar \epsilon _{ijk} J_k
Yes thanks
but how can i work this out?
Fys said:
Yes thanks
by working out all partial commutators and using the commutator between position and momentumoperators. Or starting from group theory of rotations.. but I assume this is introductory QM course, so start with the first option ;)
Start with \left[A,BC\right]=\left[A,B\right]C+B\left[A,C\right]
a couple of times til you get things like [x,p_y] ; [y,z] etc
I got the same task in my intro QM course, took me a couple of hours ;)
oke thanks :P
Easier: first work out [L_i,x_j] and [L_i,p_j] using the explicit form of L_i. Then use the [A,BC] formula to get [L_i, x_j p_k].
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
