mtayab1994
- 584
lim x(pi-2arctan(x^(2/3)))
x->-∞
I don't know how to remove undefined form. Can someone give me a hint? Thanks in advance.
micromass said:l'Hopitals theorem?
mtayab1994 said:I can't use that so can i do xpi-2xarctan(x^(2/3)) which will become:
xpi-[(2arctan(x^2/3)/x^(2/3)]*x(^5/3) , but even that still gives an undefined form.
micromass said:Why can't you use it?
This would allow to replace the x with some function of t. How does your new limit look like?t=arctan(x^(2/3))
mfb said:Which properties of the arctan function are available?
mfb said:Well, those terms all diverge, so it does not look very useful.
A limit problem is a mathematical concept that involves finding the value that a function approaches as its input approaches a certain value. It is often used to analyze the behavior of a function near a specific point.
A limit problem can be considered tricky when it involves a function that is not continuous or has a discontinuity at the point being evaluated. It can also be tricky when the function is undefined at that point.
To solve a tricky limit problem, you need to first determine if the function is continuous at the point being evaluated. If it is not, you may need to use algebraic manipulation or other mathematical techniques to simplify the function and evaluate the limit. You may also need to use specific limit theorems or rules to solve the problem.
Yes, a limit problem can have multiple solutions depending on how the function behaves at the point being evaluated. It is important to check for possible discontinuities or undefined values that may affect the solution.
Limit problems are important in science because they allow us to model and understand real-world phenomena that involve continuous change. They are used in many areas of science, such as physics, chemistry, and biology, to analyze and predict the behavior of systems.
