Tricky minimum distance vector problem
  • Thread starter Thread starter Lucy Yeats
    Minimum Vector
Lucy Yeats
The line intersects a plane at an angle alpha=2pi/3. The line is defined by rn, and the plane by r.m=0, with n and m unit vectors. Calculate the shortest distance from the plane to the point on the line with μ=2.
I want to find the value of μ at the point of intersection. Then it will be easy to find the distance, as d=(2-μ at intersection)sin(2pi/3). However, I don't know how to find μ. Any hints?
I'm still stuck. Any ideas would be much appreciated!
Hi Lucy Yeats! :smile:
To find μ at the point of intersection you need to substitute the equation of the line into the equation of the plane.
That is (μn).m=0. From this it follows that μ=0.
That's funny!
Yes, the origin is on the line and the origin is also in the plane.
Btw, the regular way to calculate the distance of a point to a plane, is to project any vector from the plane to the point, onto the unit normal vector.
You can do this with the dot product.
If n and m are perpendicular, surely mu could be anything? How do you know that they aren't perpendicular?
I'm guessing that you have to use the angle 2pi/3 in some way?
Thanks for helping, btw!
Yes.
What would happen (geometrically speaking) with the point of intersection if n and m are perpendicular?
Yes.
But first you need the formula for the distance of a point to a plane:
distance = (any vector from plane to point) . (normal vector of plane)
Actually, your distance formula d=(2-μ at intersection)sin(2pi/3) also works.
Just fill in the μ we just found for the intersection.
Btw, did you know that n.m=sin(2pi/3)?
Ah, I see, they can't be perpendicular because then the angle wouldn't be 2pi/3. so mu has to be zero.
Brilliant, thank you very much!
You're welcome! :smile:
