Tricky questions about glass transition and crystalline melting
The crystalline melting temperature (Tf) of polyethylene (PE) is higher than that of polyethylene oxide (PEO) due to the significantly greater molecular weight of PE, which leads to a higher melting point. The confusion arises from the crystallinity percentages of these polymers, where PEO has a higher crystallinity but a lower melting temperature. For polypropylene (PP), its lower glass transition temperature (Tg) compared to polyvinyl chloride (PVC) and polystyrene (PS) is attributed to the presence of methyl side groups that hinder efficient packing of polymer chains. In contrast, PVC's structure allows for efficient packing due to dipole interactions, while PS benefits from π-π stacking of aryl side groups, resulting in higher Tg values. Understanding these relationships clarifies the differences in thermal properties among these polymers.
ymhiq
How do you explain that crystalline melting temperature Tf of PE is greater than the Tf of PEO? How do you explain that the glass transition temperature of PP is lower than the glass transition temperatures of PVC and PS?
None
I read something about the higher the molecular weight the higher the crystalline melting temperature, so I found that PEO is also PGE and its molecular weight goes from 1000 to 20000, PE has a molecular weight between 10000 and 40000. It makes sense. I kept reading and I found that PTFE has got a Tf of 330 ºC because of its crystallinity 94% so I found that the crystallinity of PE is about 45% but crystallinity of PGE is 83% and it do not make sense.
I got confused. I decided to answer the next question but...
I also read that glass transition temperature is related to crystalline melting temperature and its a fraction of its value(tow thirds for unsymmetrical polymers and half for symmetrical ones). However PP molecular weight is between 200000 and 700000, PVC molecular weight is between 100000 and 200000 and finally PS is between 50000 and 100000 and it do not make sense.
Any help would be greatly appreciated.
1) You mean PEG (polyethylene glycol) instead of PGE (polyglycerol ester). PEO (polyethylene oxide) is the same as PEG, although they sometimes refer to different molecular weight regimes. In general, yes, the MW of PEO will be significantly less than PE, and this leads directly to the observed higher melting point of PE.
2) For the glass transition temperature, you're no longer looking at the molecular weight, but rather how easily the polymer chains pack in a crystalline configuration versus how easy it is for them to pack amorphously. For PP (polypropylene), each monomer unit has a methyl side group which inhibits efficient packing and lowers the glass transition temperature: the temperature where the polymer transitions from largely crystalline to largely amorphous. This is most apparent when comparing atactic PP (methyl group is "randomly" placed on the polymer backbone) to isotactic PP (methyl group is periodically placed on polymer backbone). The Tg of atactic PP is quite a bit lower than that of isotactic PP. On the other hand, PVC (polyvinyl chloride) packs very efficiently because the chlorides provide enough of a dipole to match up in a crystalline fashion (this doesn't happen with the nonpolar methyl groups). For the case of PS (polystyrene), the aryl side groups can ##\pi-\pi## stack and create crystalline interactions, so it too has a relatively high Tg.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
