What direction does a tricycle initially move when pulling a rope to the left?
  • Thread starter Thread starter donald1403
    Rotation Wheel
When pulling the rope to the left, the tricycle initially moves backward to the right due to the position of the rope below the wheel axis. This movement is explained by the torque exerted on the wheel, which causes it to push horizontally against the ground. According to Newton's third law, the ground reacts with an equal and opposite force, resulting in the tricycle's backward motion. The discussion highlights the importance of understanding forces and torque in relation to motion. Ultimately, the mechanics of the tricycle's movement illustrate fundamental physics principles.
donald1403
http://img98.imageshack.us/my.php?image=tricyclejz7.jpg
A. If you pull to the left on the rope above, which way does the tricycle initially move?
B. Why? Explain your answer above. (4 key concepts)
p.s for Q A, i believe the tricycle will go backward (to the right) since the rope is located below the axis of wheel.
but for Q B, i don't really know what to answer. it is extra credit point thing due 2morrow Dec 7th, so if sum1 could just tell me the answer, it will be helpful to me.
thx
soe
As the wheel rotates around its point of contact with the ground pushes horizontally on the ground due to the torque exerted on the wheel. In which horizontal direction will the wheel push on the ground? How does Newton's third law come into play here concerning this pushing force?
We find a similar situation concerning the downwards force (its weight) that the wheel exerts on the ground. The ground responds with the normal force.
thanks andrevdh... i got full extra credit points for that.. really appreciate it..
donald1403:smile:
