Solving 4x for sin^-1(1) between -pi and pi
  • Thread starter Thread starter spynjr
    Pi
The problem involves solving the equation sin(4x) = 1 for angles x in the range -π to π. The primary solution found is x = π/8, derived from setting 4x equal to sin^(-1)(1), which equals π/2. However, the discussion clarifies that the second proposed solution, x = 7π/8, is incorrect, as it does not satisfy the original equation. The correct approach involves identifying additional values of 4x where sin(4x) = 1, specifically in the intervals [0, 4π] and [-4π, 0]. Ultimately, the only valid solution within the specified range is x = π/8.
spynjr
Find all angles x, -pi <= x <= pi which satisfy sin4x = 1
Solved x, ie
4x = sin^-1(1)
4x = pi/2
x = pi/8
Sine is positive for angles in quadrants one and two, so there's one other angle which is in quadrant two?
x = pi - pi/8
x = 7pi/8
Final answer, x = pi/8, 7pi/8
Just not feeling confident. There are about five other similar questions, ie solving x between -pi and pi
Well, you could always just plug your solutions into a calculator. :)
But really there is only 1 point on the circle that sin(x) = 1. This is at pi/2. But the function you are given multiplies whatever argument you pass to sin by 4. In order for this to come out correctly, you need to divide pi/2 by 4.
Your work looks ok, but there isn't a solution in quadrant 2.
Solved x, ie
4x = sin^-1(1)
4x = pi/2
x = pi/8
x = pi - pi/8
x = 7pi/8
x = pi/8 is a solution, but 7pi/8 is not.
Since your solutions have to satisfy -pi <= x <= pi, then -4pi <= 4x <= 4pi. There are two values of 4x for which sin(4x) = 1, of which one of them is pi/2, hence x = pi/8, which you've already gotten. What is the other value of 4x in [0, 4pi] for which sin(4x) = 1? Once you get it, you can solve for x.
Also, there are two values of 4x in [-4pi, 0] for which sin(4x) = 1. What are they? Once you get them, solve for x for each of them.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
