Simplifying with Cosine and Sine
In summary, the conversation revolves around simplifying a trigonometric expression in terms of cosine and sine only. The individual asking for help starts by flipping the fraction and reducing it. They then get stuck and ask for assistance. The conversation eventually moves on to discussing trig identities and their usefulness in university level math. The expert summarizer advises to stick with one approach when solving problems and to try using a grapher to determine if an expression is an identity or not.
soccerjayl
53
Simplify in terms of cosine and sine only.
[tex]tan^2x - {csc^2x\over cot^2x}[/tex]
From here, I assume you can flip the fraction and make it
[tex]{tan^2x\over sin^2x}[/tex]
next, i reduce it to:
[tex] (sec^2x-1) - ({sec^2x -1\over 1 - cos^2x})[/tex]
and anyway..im lost; i don't know where to stop and how simplified this can go..
beginner here..please help
thanks
that page didn't seem to load for me.
Also, haha, i thought this was beginner stuff..
youre right on the grade level, but we jumped right into this, so i figured it was the first level of trig
first of all
Dont EXPAND using the 1+ crap if you can solve by just making it into a fraction
first of all what is tan in fraction form, a ratio of what two trig functions
secondly what are csc and cot in fraction form
simplify from there
jai6638 said:
dude back in India, i did this in 9th grade..
In Canada, we have only done the very basics of trig identities.
KEep in mind I'm not talking about trigonemtric ratios and such.
I am in discrete math and physics in gr12 right now, and i still have found little use for trig identities. :S
I guess it really depends on where you are. I'm in Canada and I did this in grade 10.
trig identities will come in use when you reach university and learn integration (the opposite of differentiation) and then you'll need to use trig substitution which needs you to know how to solve trig identities.
Remember eventually something you learned will come into use
stunner5000pt said:
first of all
simplify from there
ok [tex]tanx={sinx\over cosx}[/tex]
and [tex]cscx={1\over sinx}, cot={1\over tanx}[/tex]
so then I am seeing..
[tex]{sin^2x\over cos^2x} - {tan^2x\over sin^2x}[/tex]
since it has to be in terms of cos and sin only, will
[tex]{sin^2x\over cos^2x} - {sin^2x\over cos^2xsin^2x}[/tex] work?
you didnt do the second part properly
[tex] \frac{csc^2 x}{cot^2 x} = \frac{\frac{1}{sin^2 x}}{\frac{cos^2 x}{sin^2 x}} [/tex]
now solve using the fact that
[tex] \frac{\frac{a}{b}}{\frac{c}{d}} = \frac{ad}{bc} [/tex]
further there is one more identity youll have to use after you simplify these expressions!
You can still simplify it... a lot!
Try plugging in various values for x into your starting expression.
(Try expressing it in terms of sine alone or cosine alone. You may be amused to see the result.)
isnt that what i did??
this is what you did
now what can be canceled out?
what other identity canbe used after the cancellation?
this is what I am telling you t od
using
here a = 1
b = sin^2 x
c = cos^2 x
d = sin^x x
ad / bc = ??
is what i got for the entire solution
the part you are telling me to do is the segment i have in the equation above, or [tex]{sin^2x\over cos^2xsin^2x}[/tex]
read my post above your latest
ok i was just checkin...
yes [tex]sin^2x[/tex] cancels out..
so u have
[tex]{sin^2x -1\over cos^2x}[/tex]
[tex]sin^2x -1 = -cos^2x[/tex]
so [tex]{-cos^2x\over cos^2x}=-1[/tex]
good?
awesome now you got it
remember don't use the 1+ identities first, try and make the ratios first and then see what happens
but in some cases the opposite may work better
stick with one approach if one takes longer then abandon it for then and return (if on test)
ok thanks a lot!
i have another question if u could just lead me in the right way..
The problem is to use a grapher to see if it is an identity; if not, make a counter example.
[tex]sin^4xcos^2x = cos^2x + sin^4x - cos^6x[/tex]
when i graphed them, i found there was not an identity, or the same function..
im not exactly sure how i make a counter example; can u lead me in the right way or start me off?
soccerjayl said:
ok thanks a lot!
i'm not sure what the counter example is supposed to mean? are you supposed to make an identity out of the function sin^4 x cos^2 x? if so you could do that several ways. just substitute the cos^2 or sin^2 as appropriate to express the product as a sum.
if not I've got no clue on what a 'counter example' is. maybe doing the same for the right side, but i think that would really suck eggs.
oh someone on S.O.S. Mathematics Forum told me that a counter example is when you just plug in a value for x and prove that the sides are not equal..just in case u wanted to know
thanks for the help
ahh the horor of grade 11 math X_X
Related to Simplifying with Cosine and Sine
What is the difference between Cosine and Sine?
Cosine and Sine are both trigonometric functions used to calculate the relationship between the sides and angles of a right triangle. The main difference between them is that Cosine calculates the adjacent side over the hypotenuse, while Sine calculates the opposite side over the hypotenuse.
How do you simplify expressions using Cosine and Sine?
To simplify expressions using Cosine and Sine, you need to use the trigonometric identities, such as the Pythagorean identities, double angle identities, and half angle identities. These identities allow you to rewrite the expressions in a simpler form by substituting one trigonometric function for another.
What are the common mistakes to avoid when simplifying with Cosine and Sine?
One common mistake is forgetting to use parentheses when substituting one trigonometric function for another. This can lead to incorrect simplifications. Another mistake is not recognizing when to use the Pythagorean identities, which can result in more complex expressions. It is important to carefully follow the steps and pay attention to the identities being used.
Can you use Cosine and Sine to solve real-world problems?
Yes, Cosine and Sine can be used to solve real-world problems involving right triangles. For example, they can be used to find the height of a building or the distance between two objects. These functions are also used in fields such as engineering, physics, and astronomy to calculate various measurements.
Is there an easy way to remember the trigonometric identities?
One way to remember the trigonometric identities is to create a study guide or flashcards with the most commonly used identities. Another helpful tip is to understand the patterns and relationships between the identities, as this can make it easier to remember them. Practice and repetition are also important in memorizing the identities.
  • Calculus
  • Differential Equations
